My Industrial Cabin Build
   / My Industrial Cabin Build #4,303
Saw this in your video:
That clamp is not correct for the cord and will probably eventually cut through and short it out. Yeah it will take years, most likely, but I've seen it. The good news is you only need to swap it out for a different type of fitting:
There are different sizes of these so you need to measure the diameter of the cord first, and also get the right size for the knockout in the box cover plate (1/2" or 3/4"). Odds are, the one I linked is the right size for you, but you need to verify. There are even more serious styles of support/strain relief for pendant cords but those are for bigger, heavier cords. The load on this is very light as the fixture is probably only a few ounces or so, so this style should be sufficient.
When do you think you are going to get to move in? Looks like you are getting pretty close to ready for the COO inspection. (y)
Thank you. I didn’t know they had these. I am ordering 6 and will replace the ones for the kitchen lights as well.
   / My Industrial Cabin Build #4,305
Nice work and keeping the push going forward !
Have you thought about how much more work it has been to keep your electrical work exposed vs running it all in the walls ?
I was wondering, isn't it about time to focus somewhat on the apple orchard ? Yikes...
Apple trees have been looking good but 4 days of rain is bad news. I will be spraying for rust this week.
As for the electric exposed, it wasn’t by desire. The walls and ceiling panels come with channels cut in them but you have to put 2x6 splines in on each side for the walls so you would have to drill that. Then you would have to pull wire thru those 1.5 inch foam holes and cut your light box opening right on that channel. For our walls,our posts go all the way to the outside, blocking the wire channels. It wasn’t supposed to be that way but there was a problem with the piers in the slab. My architect came up with this as a solution. It was more cost and more work for us. Since I had to do that for the main part I did it for the rest of the exterior walls. It has been quite a chore. There is a long list of things I could have done differently. But that only helps the next person if they are listening. I don’t plan to build another house.
This one took too much out of me.
   / My Industrial Cabin Build #4,308
... There is a long list of things I could have done differently. But that only helps the next person if they are listening. I don’t plan to build another house.
You have taken on a monumental build that has been a lot of fun to watch, but also overwhelming in what you are doing. In my experience, once it's behind you and you are dealing with the next major project, the pain from this one will fade, and the odds of you doing it all over again will increase.
   / My Industrial Cabin Build #4,309
I hear that! I'm finally within a couple weeks of completing window trim now. Then still have baseboards to wrap up, and I am dragging at this point. Finishing up making and installing doors took a long time and really took it out of me, and that finally wrapped up last Aug. July will be 10 yrs from when we officially broke ground, but in reality we started clearing in 2009 so more like 14+ yrs now. Given my age and how much I have slowed down (prob just a couple years or so older than you) there is no way I will ever do it again. Which is the only reason why I disagree with Eddie's comment on "soon forget the pain and do it again". This house was too big, expensive and complex to even think about doing again.
   / My Industrial Cabin Build #4,310
Building an entire house while simultaneously working a full time job (so as to be able to afford it) is a fairly ridiculous endeavour that few humans can fully appreciate.
My best buddy build his house next door mostly solo. I put in dozens of hours with him, helping with site prep, material deliveries, some framing, and a lot of the drywall hanging. But he spent 12 months of basically working two full time jobs and not seeing his wife and kids much in order to get it habitable.
Shoot, we hired a contractor for our build, but on a time and materials basis - so you can bet I was there almost every day making sure time wasn't spent on site cleanup or other dumb stuff by our carpenters at their full hourly rate. And then I did allllll the interior finishing to save costs further. It was a long year.
This thread is on a whole 'nother level of persistence and commitment. Kudos.
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
1995 Rinker Captiva 190 (A55302)
1995 Rinker...
1990 TRAIL MASTER TRANSPORT TRAILER (A55745)
1990 TRAIL MASTER...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A55745)
2017 TROXEL 130...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
TANK MANIFOLD (A55745)
