Good morning!!!!
   / Good morning!!!! #168,781
On the flip side, brown rice can also have high amounts of arsenic (depending on source) and contains phytic acid, which impedes the absorption of essential minerals like zinc and iron. The glycemic index of white rice can be lowered by cooking, refrigerating overnight, and reheating the next day. The cooling/reheating process converts the starch to a less-digestible form. By pairing rice with other healthy accompaniments, to losses from removing the “brown parts” is offset.
if one is really cynical, one may posit that the brown rice craze was started to simultaneously reduce processing costs while raising prices for a “healthier” product…
Do the pros of brown rice outweigh the cons of arsenic? Here is the answer.
   / Good morning!!!! #168,784
I do like the nuttier flavor of brown rice from time to time. Sophie grew up on white only, maybe due to her Mom coming from Osaka. Me, my Mom made Uncle Ben’s mostly.
   / Good morning!!!! #168,785
Drew- I am sorry to read about your molar. I recently had a similar experience. I use those plastic PIC sticks. They work pretty well until one of my "sharp/cracked/chipped" teeth shreds the fibers.
I too like those plastic ones with the floss, but inevitably I’ll break the very tip. Still like the old fashion wooden toothpick.
   / Good morning!!!! #168,787
Happy Birthday Ted. I wish you many more trips around the sun in good health and happiness. I hope that your birthday expectations are met or even better, exceeded.
   / Good morning!!!! #168,788
I only do this at home at this point, but I will use the PIC sticks and/or floss during 🍸 🍸. The sticks are also good at removing an occasional errant🐕 hair that may fall into the🍸
This afternoon's weather is turning out better than predicted with more sun than clouds. The current 55ºF is today's high temperature so far.
1795 (A58375)
1795 (A58375)
3-5TH WHEEL PLATES (A58216)
3-5TH WHEEL PLATES...
2014 K-Z RV STONERIDGE 38FT RV TRAILER (A58214)
2014 K-Z RV...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 9,000 lb. Capacity, 45' Reach, Rear Steer, 60" (A59076)
Gradall 53409-45...
2009 PETERBILT 340 FLATTOP SLEEPER (A58214)
2009 PETERBILT 340...
