LS 225E Instrument Cluster Not Working
/ LS 225E Instrument Cluster Not Working #1
ChuluTrac
Chuluota, FL
LS M225HE
I have a 2 year old LS 225HE and today the instrument cluster stopped working. No RPM, Hours and both gauges were at zero. Everything else worked fine on the tractor. I called Bruno's tractor, where I bought it, and the tech suggested that I look at the ground on the firewall. Sure enough, that was the problem. The paint had not been removed under the ground wires, so I sanded it off, reinstalled the ground wires and put some grease on it. Problem solved.
/ LS 225E Instrument Cluster Not Working #2
Might want to do the same to the Engine ground, follow the Negative cable from the battery to where it connects to the tractor/Engine.
Seems this a common problem and not just on LS tractors.
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
3268 (A63117)
3268 (A63117)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
