EX2900 Idle speed
/ EX2900 Idle speed #1
BigRosto
St.Johnsville
Cub Cadet Yanmar EX2900
EX2900 Rpm engine speed often hangs up at working speed and doesn't want to return to idle. Spraying cleaner/lube on throttle-spring assy at pump seems to help for a while only. Ant thoughts?
/ EX2900 Idle speed #2
Does the spring look to be weaker than new? Does the spring have corrosion?
This is right from the Yanmar manuals.
There isn't a spring in the throttle assy. Instead it rely on friction conical washers (item-2)
Looking at the parts diagram, you can make an easy adjustment, ever so slightly, back off item-10 and item-11. Then adjust item-11 to sit where it's needed to place proper tension for the throttle to behave correctly. Then tighten down item-10 to hold item-11 in place.
Should you need manuals of parts support, our Yanmar group is here to help you,
/ EX2900 Idle speed
The governor shaft sticks. Return spring and throttle shaft are free, so problem seems to be internal to the governor. Can return it to idle setting with a socket on the shaft nut. Looking for a diesel mech who can go in to the gov. and put it back together.
/ EX2900 Idle speed
thanks to Bmaverick. Turns out the throttle shaft was bent inside the dash. Works fine now.
(2) New 14-17.5 NHS tires w/ fluid on 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2017 Mack Semi (A64047)
2017 Mack Semi...
Pig Statue (A64127)
Pig Statue (A64127)
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
Iranch IRGC40 (A64127)
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
