Look for an air leak in the suction line to the fuel pump. If you smear grease all over that line it should stop that problem temporarily. If so - that is the line to replace or tighten connections on.Tn75 new holland 1998 engine stops at low idle below 1000 rpm. Changed fuel filter, very dirty, helped only a little.
