Backhoe Need to rebuild hydraulic pump on 580 CK
   / Need to rebuild hydraulic pump on 580 CK #1
James Lattner
Case 580 CK
I've been working on the hydraulics of an old Case 580 CK backhoe loader that I inherited (about 1970 vintage). I've replaced the seals in 3 leaking cylinders and replaced 23 hydraulic hoses. The hydraulic oil looked like chocolate milk, so I drained out all I could and refilled with 50/50 diesel/hydraulic fluid mix. I cranked it up and everything was looking good, until the hydraulic pump started spraying fluid everywhere . . . I think the diesel must have dissolved the gunk that was keeping the pump shaft sealed!
So, I've taken off the pump and taken it apart . . . it doesn't look too bad, but it needs a new shaft seal. I also need all the other gaskets and o-rings to go with it. I've searched the internet, but I cannot find any rebuild kits for this pump. I can find a new aftermarket pump for about $400 . . . is this my only choice?
   / Need to rebuild hydraulic pump on 580 CK #2
Case probably has kits for it. CASE
Place youe cursor on "parts & service". A drop down menu will appear.
Select "search for parts".
Enter 580CK in the model space, and hit enter. You will need to determine which loader/backhoe model you have, and the serial number of the unit, as it looks like they used more than several pumps, throughout production.
Just a couple I looked at, they have kits, or reman'd pumps.
   / Need to rebuild hydraulic pump on 580 CK #3
   / Need to rebuild hydraulic pump on 580 CK #4
   / Need to rebuild hydraulic pump on 580 CK #5
Im looking for a pump or the part numbers. Tough going
The hydraulic pump is out of a very old case 580...70s. . The md is 580ck sn 8346514. Whether it is a b I've been told differently based on the md and sn. I would need the coupler and spline too. The engine is a g1880. The spline shaft coupler look to be maybe 5 8ths wide? ..13 spline cavities and 13 ribs.
   / Need to rebuild hydraulic pump on 580 CK #6
Try calling case salvage at 740 432 5920 talk to bob.
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
FLOOR PRESS (A55745)
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
STORAGE FEES (A56138)
2023 PETERBILT 567 VOLUMETRIC CONCRETE (A55745)
2023 PETERBILT 567...
