Backhoe Need to rebuild hydraulic pump on 580 CK
   / Need to rebuild hydraulic pump on 580 CK #1
James Lattner
Case 580 CK
I've been working on the hydraulics of an old Case 580 CK backhoe loader that I inherited (about 1970 vintage). I've replaced the seals in 3 leaking cylinders and replaced 23 hydraulic hoses. The hydraulic oil looked like chocolate milk, so I drained out all I could and refilled with 50/50 diesel/hydraulic fluid mix. I cranked it up and everything was looking good, until the hydraulic pump started spraying fluid everywhere . . . I think the diesel must have dissolved the gunk that was keeping the pump shaft sealed!
So, I've taken off the pump and taken it apart . . . it doesn't look too bad, but it needs a new shaft seal. I also need all the other gaskets and o-rings to go with it. I've searched the internet, but I cannot find any rebuild kits for this pump. I can find a new aftermarket pump for about $400 . . . is this my only choice?
   / Need to rebuild hydraulic pump on 580 CK #2
Case probably has kits for it. CASE
Place youe cursor on "parts & service". A drop down menu will appear.
Select "search for parts".
Enter 580CK in the model space, and hit enter. You will need to determine which loader/backhoe model you have, and the serial number of the unit, as it looks like they used more than several pumps, throughout production.
Just a couple I looked at, they have kits, or reman'd pumps.
   / Need to rebuild hydraulic pump on 580 CK #3
   / Need to rebuild hydraulic pump on 580 CK #4
   / Need to rebuild hydraulic pump on 580 CK #5
Im looking for a pump or the part numbers. Tough going
The hydraulic pump is out of a very old case 580...70s. . The md is 580ck sn 8346514. Whether it is a b I've been told differently based on the md and sn. I would need the coupler and spline too. The engine is a g1880. The spline shaft coupler look to be maybe 5 8ths wide? ..13 spline cavities and 13 ribs.
   / Need to rebuild hydraulic pump on 580 CK #6
Try calling case salvage at 740 432 5920 talk to bob.
2020 INTERNATIONAL MV607 (A55745)
2020 INTERNATIONAL...
2011 KENWORTH T800 (A55745)
2011 KENWORTH T800...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
