Hay mower
/ Hay mower #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
Looking at a new hay disc mower.
Looking at a mower with the name of Morra.
Also sold under other names such as Farmmax, and Fort
From what I find, they are made in Italy
I can't seem to find any reviews on this mower, and was wondering if anyone here has any experience with these mowers.
Thanks
/ Hay mower #2
Mine is a 10' Bush Hog brand. Don't know if it is marketed under another name though.
/ Hay mower #4
Thanks
I've never seen a Morra, Farmmax, or Fort disc mower unless they were/are actually the OEM on somebody else's mowers, and even then it would only be an older or budget-line model as the major manufacturers either make their own main-line stuff or have another major OEM make it for them (e.g. Deere's 3 point disc mowers are Kuhns with green paint.) I don't think I would be real eager to buy a budget disc mower from a not well known maker, particularly since it would be almost guaranteed to be a gear bed unit. Those are particularly critical to how well they are put together and failures tend to be catastrophic. I am partial to the shaft drive modularized units after having worked on them, they are generally repairable although dropping the cutterbar and separating the modules out is a bit of work.
/ Hay mower
got a vicon now that's a gear bed unit. I was under the impression they all were geared
/ Hay mower #6
Nope. CaseIH/New Holland uses a modular shaft-driven cutterbar on their Discbines and their "nicer" disc mowers. Everything Vermeer currently makes is modular shaft-driven too, but a different design than CNH uses. Most of the rest are gearbed though.
/ Hay mower
who builds those for case/NH ?
my vicon is built by Greenland / Holland
/ Hay mower #9
Mower cutter bar or the whole mower? I think the NH discbines are made at the New Holland plant in New Holland, PA along with the balers.
/ Hay mower
Probably the same factory that makes the Vicon. It's also made in Holland
2016 Ford F-550 4x4 ETI ETC37IH 37ft. Insulated Bucket Truck (A64556)
2016 Ford F-550...
2022 EZ-GO ELITE...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2022 EZ-GO ELITE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2016 CATERPILLAR 311FL RR EXCAVATOR (A65053)
2016 CATERPILLAR...
