etpm
- Joined
- Jun 30, 2021
- Messages
- 2,394
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
My Yanmar YM2310 has been hard to shift recently. I was using it for some tilling and I was shifting between crawl, first, and second gear. Before attempting to shift I would make sure the Power Shift lever was in neutral and then I would try to shift the main tranny. And the shifter lever just plain didn't want to go into gear. I would need to fuss with it and sometimes put the tranny into third or fourth gear and then try the lower gears again to enable the machine to go into gear. Because my back is fusing and I cannot bend over as far as I used to I made an extension for the crawl knob so it is very easy to pull all the way up. And still it was quite hard sometimes to get it into gear. I checked the tranny oil level and it is fine. Any suggestions?
Thanks,
Eric
Thanks,
Eric
