   / Share Pics of People Hauling or Towing Something Wrong #18,041
I thought I was going to have one to share today. A small sized SUV was towing an triaxle trailer up the interstate, which was swaying so much they could barely keep it in their lane. I popped the disc from my dash cam when I got home but for some reason it had already looped over that spot.
I assume you meant an SD card instead of a disc. Just get a larger SD card, I have a 256GB card in my dash cam, and it records about 20 hours of HD video before it starts overwriting the oldest videos.
   / Share Pics of People Hauling or Towing Something Wrong #18,042
Most dash cams have a lock button to keep that footage from being overwritten. I've got a 128gb and hit button then pull off when back home. Have 2 so just play switch with them, that way always a card in it!
   / Share Pics of People Hauling or Towing Something Wrong #18,043
I am planning to upgrade my 2-1/2" receiver ball mount to adjustable and am presently looking at the Curt 45902. Any other recommendations? Blue Ox BLU85XR looks similar, maybe the same?
   / Share Pics of People Hauling or Towing Something Wrong #18,044
I doubt all the hitches I have bought in my short 66 years on earth would total up to $447.
   / Share Pics of People Hauling or Towing Something Wrong #18,045
Most of my hitches I've picked up out of the road. I believe that I've bought one in my life, and that was because I didn't have one with me when I bought a trailer.
   / Share Pics of People Hauling or Towing Something Wrong #18,046
I’m a cheap skate... :confused:
it’s rated at 5k hitch weight. :)
That's 5K towing capacity, 500 lbs hitch weight. Like most people, I use a 5K hitch for my 7K trailer but technically that's towing wrong. Theoretically, my truck is limited to 5K without a weight distributing hitch also, but I don't have one.
   / Share Pics of People Hauling or Towing Something Wrong #18,047
Wow - I run an 18,000+lbs rated hitch for my 12k dump and even my smallest trailer is rated at 3000lbs and I run an 8000lbs hitch (2200lbs tongue weight rated for both). I much rather have an overrated hitch than an underrated one.
I have no problem paying for a good hitch. I figure $300 -$400 is not a big deal when I may be towing a $50,000+ vehicle or even a $20K UTV.
   / Share Pics of People Hauling or Towing Something Wrong #18,048
It's a bit different, but years ago I sold a trailer which I had converted from a small boat trailer buy attaching a 4x8 sheet of plywood to the platform. The guy was going to tow his dressed up Yamaha behind his RV. It was his money but the trailer was grossly inadequate for what he was doing.
   / Share Pics of People Hauling or Towing Something Wrong #18,049
Weigh Safe makes nice hitches. Easy to check tongue weight. Many models are aluminum...easier for me to lift.
Definitely match shank size to receiver...the adaptors are a real compromise.
   / Share Pics of People Hauling or Towing Something Wrong #18,050
Consider Weigh Safe. The scale has helped me adjust a lot of loads for Safe travel. You can change ball sizes in seconds. And you can key everything alike including pin and pad locks.
2020 CAT D6K 2XL (A55272)
2020 CAT D6K 2XL...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A56435)
New Holland 1412...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
HUSQVARNA PUSH MOWER (A58374)
HUSQVARNA PUSH...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
