Kubota rear wheels
/ Kubota rear wheels #1
leoball
Logan, WV
Kubota L3010
Hello all, I have a 2003 Kubota L3010 tractor -it has hoop type wheels on the rear-4 bolts and a deep offset (24 X W15L is stamped on the rim). The tire size is 420/70-24-- the center of the wheels are breaking and I would like to buy some rear wheels and tires. Contacted a wheel and tire place in Ohio and they advised its a metric bolt pattern and that I would have to buy from a dealer?
It is a six lug, 6 5/8" with a center hole of 5 3/8". It is a four wheel drive and the front tires are 16.5"
Would appreciate any guidance at all.
Thanks, Leo
304-687-2730
/ Kubota rear wheels #2
More than likely it is a 170mm bolt dia (6.693") and has a 135mm center pilot hole (5.315"). Are you sure there not 6 bolt wheels?
/ Kubota rear wheels #3
Thanks, Leo
304-687-2730
Contact Hey Wheel Co. HEY WHEEL HOME-WHEELS, RIMS, AIRCRAFT TIRES FOR AG USE.
They have everything. I bought new wheels to replace my industrial R series tires with Ag tires to conform to our planting widths. They sent me the rims then sent an invoice later. Nice folks .
Thanks, Leo
304-687-2730
I found center disks at a Kubota dealer--thanks.
2017 Link-Belt 350X4 Hydraulic Excavator (A64553)
2017 Link-Belt...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
2016 JLG 800AJ 4x4 80ft Articulating Boom Lift (A64553)
2016 JLG 800AJ 4x4...
2006 Heil DOT 407 Aluminum 9,000 Gallon Ethanol T/A Tanker Trailer (A64194)
2006 Heil DOT 407...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2017 DITCH WITCH JT20 HORIZONTAL DRILL (A63276)
2017 DITCH WITCH...
