Carpenter Bees ...
   / Carpenter Bees ... #41
   / Carpenter Bees ... #42
If insecticides that list bees as a target arent working, you either arent mixing it correctly or applying it wrong.
dont target the bees. Spray the WHOLE structure. At any given time you are only seeing a fraction of the carpenter bee population in your area. And unless you want to camp out in the barn 24/7 for about a week and successfully kill ALL that come near, you will never be rid of them.
Bifen has great residual life. You spray all the rafters and wood where the bees land. It stays active for weeks. All they gotta do is land somewhere you have sprayed and their time is very limited.
There is TWO bifin's. There is i/t and xts. The xts is about 4x more concentrated. Half an ounce per gallon is all it takes for the XTS.
I also use bifen xts on my yard. 6oz/acre. No fleas or ticks if you have outside dogs that way. Or ants, termites, etc.
Bifen is about the broadest spectrum insecticide you can buy. It pretty much kills any and ever insect. And is the SAME THING that an exterminator is gonna charge you hundreds to spray.
   / Carpenter Bees ... #43
Sounds like it will kill good insects too.
In my old neighbor hood my neighbor sprayed her lawn, end of the lightning bugs and butterflies, and less birds etc.
   / Carpenter Bees ... #44
It sure does. IF they dont like it.....they can hang around in the half of my yard that I DONT spray outside my dog fence.....or move on over to the neighbors yard.
But I also spray for weeds/clover/etc. My yard is JUST GRASS. SO the pollinating insects not have any reason to be on my yard. They can go pollinate the neighbors dandelions and clover.
   / Carpenter Bees ... #45
I have no idea if what I use kills lightening bugs or not.
If they boring into my barn rafters, the stuff I posted will stop them.
I sprayed the other day, and went back to the barn today and found several wood boring bees laying on the ground dead, and none flying around.
With this chemical I posted, I spray all the wood where they have been boring.
Sad part is, they'll be back before summers out,. I'll continue to spray every couple weeks, and next year too !
   / Carpenter Bees ... #46
I would think if you are spraying the barn wood it would NOT affect lightening bugs, insects and honey bees. If spraying a yard/fields I could see it harming pollinators.
   / Carpenter Bees ... #47
My pastures and all pastures around me are sprayed with 2-4-D, or Grayson .
very few lightening bugs and bees around
   / Carpenter Bees ... #49
2-4-D and GRAZON are plant control products, not insect control.
NPIC says 2-4-D is practically non-toxic to bees.
I would imagine GRAZON is similar.
Farmers do not go out and target bees,, they are more concerned about pollination than 99% of homeowners.
I doubt that 2-4-D would be in business, if it harmed insects.
   / Carpenter Bees ... #50
Carpenter bees are pollinators.
That does not make them "good",,
The kid down the street with the pickup that "rolls coal" is not considered good because his exhaust kills mosquitoes,,
Carpenter bees to LOTS of damage,, it can easily amount to thousands of dollars per year for a single home.
   / Carpenter Bees ... #51
I live in a log home and I built 6 carpenter bee traps. A 4" block of 4x4 post with 4 3/8" holes going upward into the block. The 4 holes meet inside the block to a 1/2" hole going straight down. A mason jar is mounted on the bottom of the block. The bees climb into one of the 4 entrances on the side, and then down the main tunnel into the mason jar. They can't get out. Each trap will capture 30-40 bees in a few weeks. I empty them and keep capturing more bees.
Not my video, but this is what they look like:
I have found the wood peckers do way more damage than the bees. They open up the bee tunnels and wreak havok on my log siding, in particular on my garage. The bees don't tend to bore into my log home, just the garage which has log siding on regular stick built construction.
I've made 12-15 of these and they will catch hundreds of the little buggers. I don't want to just 'empty' it as some are going to still be alive in there. I'll wait until season is over and/or take the jar down to the lake and drown them.....then turn them into potential fish-bait! (I have no idea if the fish would eat them or not.....I leave that decision up to them!)
It amazes me when the traps are up that some of them are prolific at catching the buggers.....others not so much. Not sure if it has to do with sunshine, lack of, star alignment or pot luck. Those that are prolific in catching them, I might add a second one next to it. I've got them on all four sides of the house with the most of them on the front deck area.
   / Carpenter Bees ... #52
The light that hits the jar may be the reason some traps work, and some don't.
I have read that the bees are looking for light when looking for an exit,,
so, some have said to add a crumpled piece of aluminum foil in the clear jar.
The foil will reflect light, attracting the bees to "that" exit.
It is cheap enough to try, and probably nothing negative about adding the aluminum.
   / Carpenter Bees ... #53
My understanding is the entrance hole has to be drilled on an upward angle AND closer to the top verses bottom of housing. There is a hole in the bottom for them to enter the jar.
When they get inside, they fly around... can't find their way out (since there isn't a direct view out the entrance hole because of it being angled) BUT, they see the light in the bottom.....so go there to escape, only to find themselves joining up with the rest of their ilk.
If someone tries one of these and it's not working then I'd review how it's constructed (is the hole about 1/2"? Is the hole angled upwards? Is the hole on the upper section of the box?)
   / Carpenter Bees ... #54
It doesn't harm them. It just eliminates their food source.
Just like they claim glyphosate harms humans. But it's still here
   / Carpenter Bees ... #55
I use spectracide carpenter bee and yellowjacket killer, that stuff does work on them. The straw is flexible, so I snake it into the hole as deep as able and hit the go button. The stuff foams up in there, and soon they start filing out and dropping dead on the ground. Then I plug the hole.
   / Carpenter Bees ... #56
I sprayed my cedar pergola today. Those bastards got into it, (3) holes, last April. They will have a rude awakening this spring. Mixed it a little hot too. I also have a couple carpenter bee traps I made, places around the house.
   / Carpenter Bees ... #57
I've had very good luck with the traps. I use these:
I put up 3, and caught over a hundred last season. I haven't seen any yet this spring.
   / Carpenter Bees ... #58
   / Carpenter Bees ... #59
Delta Dust and one of those puffers. Hit the holes and leave them open so other stragglers go in and get dosed too. Been doing that the last couple of years and see way fewer carpenter bees.
   / Carpenter Bees ... #60
I use the traps as well. I have 4 around the four corners of the house and only the one on the S.E. corner catches any, I as told not to empty it as the dead ones attract more. Don't know about that, but the pile keeps getting deeper. Was also told that only the females bore and that they show up a little later in the spring. Don't know about that either.
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
1995 Rinker Captiva 190 (A56438)
1995 Rinker...
