death of regular cab pickups
/ death of regular cab pickups #281
I'd have to do some research, which I will not do, but I think cabs of today are wider inside than cabs of 40 years ago. Just guessing here. :)
I know for a fact 4 men could squeeze onto a vinyl bench in a 80s era 4 speed F150 and close the doors. Not comfy but it worked.
Couldn't do that on the newer Sierras with bench or 60/40.
/ death of regular cab pickups #282
Must be a Ford thing. Haven’t seen them on Dodges, Chevys, or Jeeps in a lot of years.
It's a Ford Super Duty thing. I had a 2K power stroke as well with stick on the floor and manual hubs. It was still available in the teen model years last I looked.
/ death of regular cab pickups #283
My old U.S. Forest Service Dodge is kind of an end of an era.
I think the USFS fire trucks are still green. All other vehicles have been white for some time.
Do pickups still have a 4spd. option or manual shift into 2 or 4wd/hi-low range? Not to mention locking hubs on front axles?
Most folks don’t want a 35 yr old truck that rides like a truck, (very spartan & uncomfortable) and I agree with them.
But I‘ve kinda gotten used to the old girl.
Manual trans is dead in full size pickups as of 2018 model year (Cummins Ram only as option)
Last year for Ford Super Duty was 2010 with 6.4 powerstoke / 5.4 V8 and 6.8 V10
GMC/Chevrolet was 2006 if I remember right, 6.6 Duramax, 8.1 Vortec and 6.0 Vortec.
I had to go to an automatic on my current truck since I didn't want to pay big bucks for a Cummins ram and anything else manual was old and salt rotted to junk.
/ death of regular cab pickups #284
Not surecwhat a Sierra is? My Son has 2019 or 20 F150. Doesn't have a bench. But the cab is huge.
I can seat 4 in my 60/40 20 yr old F250. Newer F150s use a cab just as big or maybe a pinch bigger.
Not sure where to find that data.
/ death of regular cab pickups #285
It’s too bad you can’t get a manual trans anymore. I had a Spicer 7 speed (6+1) easy shift transmission in an International and it would have been great in the Ram behind the Cummins. 7th was OD.
Extremely easy to teach to shift. I could shift it clutch-less by just blipping the fuel pedal.
/ death of regular cab pickups #286
GMC Sierra, C1500 to be exact, in this case a 1/2 ton reg cab with 8 foot box. 20 year old 250 would be a Super Duty. The early 90s and older 250 used the same cab as the 150.
/ death of regular cab pickups #287
Wish I could still get a stick too.
I studied the ratios out in the G56 6-speed in the last models of Cummins Ram so equipped, they seemed spaced good, 1st is granny low and 6th over drive.
I had a ZF6 in a 7.3 Super Duty and 1st was granny, 6th overdrive, it was spaced good other than I wished it had a gear between 5th and 6th for running 70 MPH. With 3.73 axle 6th was 2000 RPM, 5th was 3000 RPM.
/ death of regular cab pickups #288
That ratio thing is the problem with my 7.3L SD AT.
OD off, 50mph, 2K rpm.
OD on, 70mph, 2K rpm
/ death of regular cab pickups #289
In general, pick-ups aren't designed anymore with it being a work vehicle as the primary design consideration. They are luxury vehicles designed to be more of a status statement. Unfortunately that is what most pick-up buyers apparently want. Their are probably a large number of pickups on the road that have never carried a load in the bed. I can't imagine buying a $60,000+ rig and using it and 'abusing' it in the way I need to use a pick-up. That's why I will stick with the '96 Dodge 1 ton I bought used a couple decades ago.
/ death of regular cab pickups #290
The 4R100 and ZF6 had the same ratios in the top gears so exactly the same problem. Both needed a gear in between, both were geared perfect for 55 MPH driving though.
3rd gear auto and 5th gear manual were 1:1
4th gear auto and 6th gear manual were 0.72:1
The newer automatics with double overdrive solved that gap issue.
/ death of regular cab pickups #291
I drove that exact truck, except white and a 250 for years for a guy I worked for. Mostly snow plowing.
Dodge Trucks were kind of made fun of back then. I thought the thing was tough as nails even back then.
Whenever somebody mentions an old a Dodge being tough I think of the line “I’m as good once as I ever was”.
/ death of regular cab pickups #296
I keep hearing this. Yet a truck today will tow more, carry a heavier payload, and pull better than its counterpart of 30 years ago. Just because they don't beat your guts out doesn't make them any worse. About 15 years ago I thought I had to have a toy, and bought a 1987 GMC "heavy half" Sierra. That truck road so hard that my dog got so she refused to get into it. And it wasnt that she minded riding; we used to log 50,000 miles per year when I was working all over 4 states.
/ death of regular cab pickups #298
Only down side to newer vehicles is, they are cost prohibitive, unable to be repaired by someone without a full shop and once their useful life is over they go to the scrap yard. Plus older trucks can be built to compare very close to their modern counterparts for a fraction of the cost of a new truck. Give me $30K and you will have a 7.3 Powerstroke or a Lb7-LLY that will put up better (better is subjective) numbers than "modern" diesels all while being able to make repairs yourself. Then there is the aftermarket problem with newer diesels. Write a tune for a post emission diesel or sell a non carb air filter and find yourself in prison. I get what people mean when they say new trucks are not designed for work. I think a better way to describe it would be that they are not marketed for work anymore. If they were you wouldn't have subdivisions filled with them. I know of very few farmers that have 100k to drop on a new truck.
/ death of regular cab pickups #299
In regards to "working on" a newer truck.... I'll bet 10% or less of readers of this thread can rebuild a carb? Or know how to set the ignition timing on an engine? Or can replace a Ujoint? Or do a complete brake job including replacing calipers?
Newer trucks require much, much less daily maintenance than older trucks. When they do require maintenance it is critical. With today's consumer's mechanical abilities as described above, it ain't happening at home. :)
yes, today's trucks are more comfort packed, more powerful, etc, than their older counterparts, but as mentioned: almost takes a 2nd mortgage to purchase new loaded, generally have less payload, & when you have to replace one of scores of sensors (some designed merely for comfort) i will stick to the tried & true for utility going from pt A to B.
Just my limited opinion at this later stage in life & of course, prob does not apply to most truck owners, cheers
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
2017 Chevrolet Equinox SUV (A61574)
2017 Chevrolet...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
TAYLOR WAY 16' DISC HARROW (A64276)
TAYLOR WAY 16'...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
