Error codes on T554
/ Error codes on T554 #1
AllenArmory
Lavon, Texas 75166
TYM T554HST Cab
I started my tractor and saw the following codes show up on the dash:
SPN: 321536
FMI: 3
This flashed alternately with two warning symbols:
I can't find anything in the user manual and my dealer is also stumped. Does anyone know what these mean?
/ Error codes on T554 #2
I hope the dealer is contacting TYM to figure this out. Hopefully it's nothing serious. Good luck
After several go arounds with the dealer and TYM, the techs at TYM said that the code on the dash can be corrected by cutting a wire that is not needed for the new dash panel (which I have). The wire is part of the engine harness. I have not done this yet. Once I do, I'll report the outcome.
/ Error codes on T554 #4
Have you cut the wire yet? I have a 554, and the dash screen is almost black. Can't see the number of hours etc. The dealer has the new part, but would like to know if I should tell him he needs to cut the extra wire...
Before cutting the wire, I started having another problem where the RPM won't go above 2000. I cut the wire and the error code went away. I'm still getting the two warning (!) symbols, though, and the RPM issue still remains.
I asked the dealer about the RPMs. After talking to TYM, he asked me to check several fuse connectors in the engine bay. He thinks that one of them may have come loose while brush hogging in the woods. I'll do that tomorrow.
Update: After checking the fuses, everything seems fine, at least to me. The dealer now has the tractor in his shop.
/ Error codes on T554 #7
I know that some of the TYM built for Mahindra have the RPM problem, but those have the Mahindra engine in them. Hopefully it's something minor.
/ Error codes on T554 #9
Have you hooked up an OBDII scanner to it?
The dealer still has my tractor. After going back and forth with TYM, TYM is sending them a diagnostic computer to figure out what's wrong. They've been waiting on the computer for two weeks.
/ Error codes on T554 #11
Keep on them. I had an issue last summer and it took almost 5 weeks to get something from TYM/Mahindra.
Resolved! My dealer had to get a diagnostic computer from TYM to determine the problem. After waiting a few weeks for the computer, it told them that the error code was due to a fuel pressure sensor problem. Part ordered. Another few weeks pass. After sensor was replaced, same problem. Yanmar called in. The sensor was the problem, but something had to be reset to enable the tractor to achieve the desired RPMs and eliminate the error code on the dash. Now, my tractor purrs like a kitten. I'm happy now, after two months of my tractor sitting in the shop.
Spring is almost here. Time to tame that overgrown property!
/ Error codes on T554 #13
SPN: 321536
FMI: 3
Allen, I hope you're still around.
I know this is an very old post but I have into this problem with my 454 HST. It has my dealer stumped.
Left engine warning light (right side cluster as shown in your image) comes on initially with key turn.
It then shuts off (normal action) once the tractor is running.
Both engine warning lights then come on, the left one flashing. They stay on and don't shut off.
Tractor seems to be running just fine. No other code shows up on the cluster. Code reader is not identifying the problem. Fluid levels are fine.
Is that similar to the issue you were having?
Thank you,
Stephen
/ Error codes on T554 #15
The left engine light indicates low oil pressure. The right is the check engine light. Low oil pressure would trigger a check engine warning. And both would illuminate.
Try changing the engine oil. If that doesn’t work try pulling the sensor of the idiot light and hooking in a guage, to see what the pressure actually is.
Sometimes the sensors go bad, and send incorrect signals to the engine management system.
One of my freinds bought a brand new Dodge with the Cummins. Anytime he got it warmed up, it would go into limp home mode. Dealer tried to trouble shoot it, and couldn’t.
Factory tech showed up, and they took it out on the highway. After forty miles it went into limp home mode. Factory tech had his laptop hooked up. The drivetrain control module thought the transmission was overheated. Tech pulled the dipstick, and stuck a long thermocouple in the dipstick tube. Sensor was showing 160-F warmer than it really was.
Dealer replaced the sensor, and the problem disappeared.
/ Error codes on T554 #16
Sorry, I have to chime in with my odd sense of humor...when I read "left engine light" I thought you had some fancy twin engine tractor!
As for those problems...sensors are nice to have, except when they fail. Next we will need sensors for the sensors.
Good luck all!
/ Error codes on T554 #17
Good luck all!
Yeah what a difference that would have made on the early Boeing 737 Max...
2011 STEPHENS 200BBL CRUDE TANKER (A67714)
2011 STEPHENS...
CLUB CAR  CARRYALL 6 (A67714)
CLUB CAR CARRYALL...
PORTA POTTY (A67714)
55 GALLON CONTAINERS OF FLUIDS QTY OF 6 (A67714)
55 GALLON...
2007 Chevrolet W4500 Landscape Dovetail Flatbed Truck (A66736)
2007 Chevrolet...
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
