Just because it is new, don't forget to check
/ Just because it is new, don't forget to check #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
Hello - here are 2 things the owner/operator should not neglect to check even if, or especially if, the tractor is new.
One thing is the front end loader subframe bolts. Mine were not tightened to the spec in the manual.
The second thing caught my eye while looking through You Tube videos on changing the HST filter- A guy said check the front axle fluid many come low from the factory. He added 2 quartz to his as did I. The MX has a big fill and a smaller check-level bolt on the dipstick side.
Lots of subframe attachment bolts took a little time to torque them all down. I'm glad I checked.
/ Just because it is new, don't forget to check #2
Yep.... found some snug, but not torqued when I got mine. I marked them after tightening, and none became loose for the next 340 hours. I still check them beginning and end of the summer.
/ Just because it is new, don't forget to check #3
New dosnt mean it wont breakdown..it just means is shiny when it does.
I should mark mine. (y)
Pallet of Anchor Shackles (A61166)
Pallet of Anchor...
2018 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2018 GENIE GS-1930...
2024 High Country Cargo 6x12 Enclosed Trailer, VIN#7FWBE1217R1035595 (A61166)
2024 High Country...
Mini rock grapples (A61567)
Mini rock grapples...
2019 John Deere 344L Articulated Wheel Loader (A60352)
2019 John Deere...
159116 (A60430)
159116 (A60430)
