MX4800 and LP RCF2772 cutter. Is it enough HP?
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #21
Won't have any issues. Running a 6' brushhog or 7' finish mower my MX doesn't even know they're back there, if anything I wish they were a little big so I didn't feel like I was over reving and underloading the engine.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #22
Newbie here... first time to own a tractor and/or any implements. Just purchased a lightly used 2017 Kubota MX4800 4WD & FEL with 450 hours on it. Separately bought a Land Pride RCF2772 rotary cutter that weighs 1072lbs. Is MX4800 strong enough for such a heavy cutter (6') or should I upgrade before I put any more hours on the tractor? My dealer has a Kubota M5660SU 4WD with FEL and only 13 hours on it.
I have about 13 acres of flat pasture land to cut and every so often move round hay bales. Main concern is:does my tractor has enough power for the cutter? Don't want to get bogged down every 5 minutes while cutting. My location is outside of the Dallas area.
Need your expertise please!
I actually mowed with a L3301 and a RCR2660. Now that I have my MX5400 its even better.
Your MX4800 will do great.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #23
Good point! I didn't think about looking into the recommended weight limitations.
I believe my manual states 1,000 pounds max for rear implements on MX4700, if I remember correctly. Would be worth a glance at your manual.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #24
no issues
One more quick question, what gear would you choose when pulling the cutter?
Mine is a shuttle shift transmission.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #26
Too many variables s to answers.
7mph is gonna be about the max speed to get a good cut. Then many factors make you slow down....rough terrain, mowing close to stuff, dense vegetation, etc. Slow down as needed. Speed up when conditions permit
Just to provide a little more context. I have about 13 flat acres, not stomps or rocks. A few Mesquite tree saplings, the grass is mostly coastal Bermuda, a have 2 donkeys and 2 longhorns, they keep the grass low.
Which out of 4 gears shoud l I use? Do I use low speed (turtle) or high speed (rabbit) with whatever gear you recommend?
Thanks everyone!
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #28
With the 8 speed shuttle (stick) transmission you have there is no such thing as the turtle or rabbit as seen on hydrostatic lawn machines for slow and fast. You select the gear that fits what you are doing and use it. Your trans is probably a 4 speed stick with a high and low range. The high and low range might even be labeled with a turtle and rabbit which is irrelevant. Lowest gear (greatest mechanical advantage) is first gear, low range. Highest (fastest but least mechanical advantage) is 4th gear in high range.
Very likely shifting gears within the 1/2/3/4 positions is synchronized (meaning it won't scrape and make a nasty noise when shifting among those gears while moving.) Shifting between low and high range is probably NOT synchronized and that means you need to stop to shift ranges. Dear me, read the operator's manual.
No one can tell you which one. Just do it. It will become natural for you to pick a medium rpm engine speed around the standard rated rpm for the engine and tractor (read your operator manual!), then select a gear, let out on the clutch and proceed. If it feels to you like it is struggling or lugging down, shift to a lower gear. If it feels like it is too easy for the tractor, shift to a higher gear or back off on the throttle. You may or may not need to shift a few times as you maneuver over your pasture while cutting. You just gotta get out there and get some experience. No one can proscribe this for you.
I am going to ask an important (and certainly not meant to be offensive, ) question: Have you driven standard transmission cars/trucks or tractors before? That makes a big difference in fully seeing your situation.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #29
Thanks everyone!
Im trying to tell you.....as fast as you can. Slow down when conditions permit.
Its not a pick one gear and never change deal. You ARE allowed to shift while in operation.
NO ONE can answer the question PERIOD. You just have to figure out what works best for you. Pick a gear....if you feel its too slow and think you can handle a little more speed......upshift a gear or two. If you pick a gear and find out you are having a hard time staying on the seat because the pasture is so rough.....downshift a gear or two. Not rocket science at all
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #30
Thanks everyone!
No one can answer that. It's likely going to change every time you mow depending on terrain, how thick the growth is, 2WD vs 4WD, how many obstacles you need to maneuver around (power steering draw), any moisture (dew), even the air temperature may impact it. Gotta listen to the tractor and what it's doing and get the most out of it you can.
MMS 800 Remote Control Lawn Mower (A60463)
MMS 800 Remote...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2021 CATERPILLAR 303.5E2CR EXCAVATOR (A62129)
2021 CATERPILLAR...
John Deere 344L Articulated Wheel Loader (A60352)
John Deere 344L...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2011 Caterpillar CB34 (A60462)
2011 Caterpillar...
