MX4800 and LP RCF2772 cutter. Is it enough HP?
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #1
GTT99
Kubota MX4800 4WD
Newbie here... first time to own a tractor and/or any implements. Just purchased a lightly used 2017 Kubota MX4800 4WD & FEL with 450 hours on it. Separately bought a Land Pride RCF2772 rotary cutter that weighs 1072lbs. Is MX4800 strong enough for such a heavy cutter (6') or should I upgrade before I put any more hours on the tractor? My dealer has a Kubota M5660SU 4WD with FEL and only 13 hours on it.
I have about 13 acres of flat pasture land to cut and every so often move round hay bales. Main concern is:does my tractor has enough power for the cutter? Don't want to get bogged down every 5 minutes while cutting. My location is outside of the Dallas area.
Need your expertise please!
According to Landpride, your tractor will do just fine.
Thank you! I looked at the specs for the cutter and the spec sheet says I need an M series for RCF2772. This is why I'm concerned if MX4800 is enough of a tractor.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #6
I believe the MX is considered a utility tractor. I don't foresee any problems.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #7
No problem at all. All MX tractor models have the same lift capacity. And 48hp (40 pto hp?) is plenty to run a 6’ cutter. The rule of thumb is 5 pto hp per foot of cutter, so 30 pto hp should run a 6’ cutter. My MX6000 doesn’t even struggle with my 6’ cutter.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #8
I'll be the 3rd to say you have NO PROBLEM using the 6ft rotary cutter on the MX4800 no matter what puzzles you find in the literature.
I used a JD 48hp tractor comparable to the MX4800 for 10 years, frequently on steep ground, rarely on level ground, cutting weeds tractor high, tall grass , many varieties of brush, etc. Not an issue.
You may have more trouble moving large round bales around. Check the weight of those bales and your FEL specs. I'd bet your MX4800 is more challenged trying to move large round bales around than it is cutting with a 6ft rotary cutter.
That M5660SU with 13hrs on it will cost you big time compared to what one assumes you must have gotten the MX4800 for having 450 hrs on it. That 450 hr is a great sweet spot to buy a tractor at rather than new, assuming you got a reasonable deal on it.
I recommend that you figure out all the CERTAIN things you will be doing with the tractor and then the OTHER things you may want to do with it in the life of it before you go buying too many things.
By the way: YouTube videos are a super way to learn about tractors and implements and just about any aspects of them. Just do a search on the LA1065 loader for example and watch one of the many videos on testing and using it. These are incredibly diverse and informative. The most 'famous' regarding Kubota are those from Messicks. You can spend a lot of time watching those as a new user and not be wasting time at all. Regarding the tractor itself, the loaders, the implements, essentially everything.
Thank you for the assurance. I got my MX4800 for $25000, the dealer wants $35000 for M5660. I can cover the $10,000 difference if the M-series tractor will make a difference in pulling the mower.
It's a life-time purchase for me, meaning I won't be swapping tractors every 3 years. I don't mind spending extra 10 grand if I HAVE to, Now, if MX4800 will do the jobs pulling a 1072lbs mower, I'm good with it. Just needed the input of those who have the experience.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #10
JWR’s response was spot on. You have your answer.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #12
I have a MX5200. Same size tractor. I use a 7 ft mower. More importantly I drag a 7 ft wide landplane with 2 blades engaged with the earth and a 500 pound weight on it. Total of which is 1100 pounds dead weight... uphill. Your tractor should be fine. Give it a go. Turn up the RPMS and select a low gear or range
By the way all MX tractors have the heavier duty class 2 rearend and hitch
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #13
I would be remiss not to mention you could just proceed with the MX4800 as-is and see how it goes. I think it safe to say you need experience more than anything else and there is only one way to get it. If the $10K to move up to the M5660 doesn't bother you now, it won't a year from now when you have some experience at least and have a much better personal feel for what you need. You would not significantly lower the value of that MX4800 by putting another 100 hours on it.
You did not say: is the 4800 a std shift shuttle transmission or hydrostatic?
My MX4800 is a shuttle shift. From my understanding, shuttle shift has a better power output than hydrostatic transmission.
I appreciate the response. Sounds like I should be ok with what I have. Just need some experience.
  • Good Post
Reactions: JWR
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #16
That's true (and I am one who prefers the stick transmission for all but lawn work.) There are many other opinions.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #17
Follow the equipment recommendations in the tractor Operator's Manual and you should be fine.
Not sure of mower weight limitations of MX series but do know that hitch components have broken three times so far on my L6060 when using a 6' Woods cutter that is about 150 Lbs. beyond the recommended cutter weight limitation.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #18
Kubota lists compatible implements for each tractor on their website.
Good point! I didn't think about looking into the recommended weight limitations.
/ MX4800 and LP RCF2772 cutter. Is it enough HP? #20
Weight is rarely the issue with rotary cutters. During most of your usage, half the weight of it is on the trailing wheel anyway. Only when lifting the cutter off the ground are you bearing all the weight and that is usually a benign and not stressful circumstance. Stop your worrywarting and go get some experience using it!
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2017 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A59906)
2017 KENWORTH T680...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2019 BOBCAT MT55 WALK BEHIND SKID STEER (A59823)
2019 BOBCAT MT55...
2025 RB66 66in Rock Bucket Skid Steer Attachment (A59228)
2025 RB66 66in...
2013 Ford Focus Sedan (A59231)
2013 Ford Focus...
