Loblolly Champion Tree in TX
   / Loblolly Champion Tree in TX #11
you mean doing something right ? lol that’s the part i don’t understand why something wrong? … but really your tree is two tree fuse together, that’s why the truck is so bing … to me it is simply older then the other one 🤷‍♂️… but i agree it is odd that the biggest loblolly pine grow in Texas, i would expect a place with more rain … it would be interesting to do a core sample to determine its age …
East Texas gets lots of rain. 10" more than in DFW annually.
   / Loblolly Champion Tree in TX #13
I was wondering of it is considered one tree or if it is two that grew together.
None of my loblolly are even close to that. The property west of us has a big double tree. Now I'm curious about how this turns out.
Good luck!
FWIW...
We got a Southern Live Oak on the local and FL state registry (no champion just big) Circumference was required to be measured at 6' IIRC...
We've looked really close and it doesn't look like two trees growing together. I guess it could be, but there isn't anything around the truck to make me think that.
   / Loblolly Champion Tree in TX #15
You are right I should said it has a very early tree fork on it
   / Loblolly Champion Tree in TX #16
I'm struggling with the thought that a tree growing on my land could be so much bigger then every other Loblolly Pine in the country. Even more, is that it's significantly bigger. It makes me think that I'm missing something, or doing something wrong.
There are state big tree registries and national registries, so you have a chance at the state champion if you don’t make the national. Contact a forester to have your tree measured with a clinometer or relaskop to get an accurate height.
   / Loblolly Champion Tree in TX #18
Loggers will take a straight stick and hold it with one end at their nose, and the other end in their outstretched hand parallel to the ground. Tip the nose end up vertical and look up across the tip at the top of the tree. You will have to walk forward or back while sigting up to the tree height. When it matches/lines up with your stick, your distance from the trunk is the approximate tree height. This is based on equal legs of a 45, 45, 90 degrees triangle. My nephew uses that method when dropping trees for our home site. Jon.
   / Loblolly Champion Tree in TX #19
That’s ok for estimating, but the big tree registry will come and accurately measure to the nearest foot before naming a new champion. They will use one of the instruments that I suggested in my previous post. The same for diameter (circumference). It has to be measured at exactly 4.5’ (breast height) above the high point of the ground at the butt.
That is the method that I used. I'm probably within a few feet of being accurate. I wasn't able to figure out how to compensate for the slight uphill slope. Just guessing, I'm probably standing 4 to 6 feet higher then the base of the tree when I was 127 feet away from it. It's not much, so I don't think it should change my distance too much.
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
CATERPILLAR D1 LGP CRAWLER DOZER (A60429)
CATERPILLAR D1 LGP...
iDrive TDS-2010H...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
RoGator RG1100C (A56438)
RoGator RG1100C...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
