Loblolly Champion Tree in TX
   / Loblolly Champion Tree in TX #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
My wife is in the Master Gardener program here in Tyler Texas that's run by A& M. While discussing native trees, she showed them a picture of our biggest tree. A Loblolly. The instructor was amazed, and told us to measure it because he thinks it's bigger then the current Champion Loblolly. Since we had never heard of Champion Trees, or that there where people who kept track of them, we where kind of shocked.
Texas Big Tree Registry
This is the website with all the information on the Champion Trees in Texas. The current number one Champion Loblolly has a trunk circumference of 165 inches. Our tree measures 205 inches around the trunk. There are three measurements and this is where it gets a little tricky. They also want the height and width of the canopy. We followed the instructions the best we could, looked on Youtube for videos on measuring trees, and came up with a height of 127 feet. The Champion Loblolly in Texas is 139 feet tall and the National Champion is 167 feet tall. And a canopy measurement of 83 feet by 78 feet for a score of 80. The three numbers are added together 205+127+80+412.
The current Texas Champion Loblolly has a score of 324 and it's in Sabine County near Lufkin.
The current National Champion Loblolly has a score of 361 and it's in the Congaree National Park in South Carolina.
It's kind of shocking to think that our tree could be so much bigger then the current State and National Trees, which makes us think we're doing something wrong. We've filled out the form this weekend and we're mailing it off tomorrow morning. Then it's a waiting game to see what A&M does.
Our Loblolly
IMG_2211.JPG IMG_2212.JPG 339119236_538664741753355_1363174327678448401_n.jpg 338747147_154117294250905_5103503852337071998_n.jpg 331893250_1227679101517966_1763764696951133440_n.jpg
   / Loblolly Champion Tree in TX #2
That's some tree! A friend's brother has the Tenn champion bald cypress on land their grandfather bought on the Hatchie River.
   / Loblolly Champion Tree in TX #3
Our Loblolly
View attachment 792774 View attachment 792776 View attachment 792777 View attachment 792778 View attachment 792779
What do you mean by that ??
''It's kind of shocking to think that our tree could be so much bigger then the current State and National Trees, which makes us think we're doing something wrong.''
   / Loblolly Champion Tree in TX #5
Such a cool looking tree! I would clean all of those little trees out from the base of it so one can get a true sense of its grandeur!!
   / Loblolly Champion Tree in TX #6
Congratulations! That's some tree, regardless. I hope that it works out.
All the best,
Peter
   / Loblolly Champion Tree in TX #7
It certainly is an unusual looking pine tree, but they claim everything is bigger in Texas, I hope that your tree turns out to be the champion.
I'm struggling with the thought that a tree growing on my land could be so much bigger then every other Loblolly Pine in the country. Even more, is that it's significantly bigger. It makes me think that I'm missing something, or doing something wrong.
   / Loblolly Champion Tree in TX #9
I was wondering of it is considered one tree or if it is two that grew together.
None of my loblolly are even close to that. The property west of us has a big double tree. Now I'm curious about how this turns out.
Good luck!
   / Loblolly Champion Tree in TX #10
you mean doing something right ? lol that’s the part i don’t understand why something wrong? … but really your tree is two tree fuse together, that’s why the truck is so bing … to me it is simply older then the other one 🤷‍♂️… but i agree it is odd that the biggest loblolly pine grow in Texas, i would expect a place with more rain … it would be interesting to do a core sample to determine its age …
   / Loblolly Champion Tree in TX #11
East Texas gets lots of rain. 10" more than in DFW annually.
   / Loblolly Champion Tree in TX #13
Good luck!
FWIW...
We got a Southern Live Oak on the local and FL state registry (no champion just big) Circumference was required to be measured at 6' IIRC...
We've looked really close and it doesn't look like two trees growing together. I guess it could be, but there isn't anything around the truck to make me think that.
   / Loblolly Champion Tree in TX #15
You are right I should said it has a very early tree fork on it
   / Loblolly Champion Tree in TX #16
There are state big tree registries and national registries, so you have a chance at the state champion if you don’t make the national. Contact a forester to have your tree measured with a clinometer or relaskop to get an accurate height.
   / Loblolly Champion Tree in TX #18
Loggers will take a straight stick and hold it with one end at their nose, and the other end in their outstretched hand parallel to the ground. Tip the nose end up vertical and look up across the tip at the top of the tree. You will have to walk forward or back while sigting up to the tree height. When it matches/lines up with your stick, your distance from the trunk is the approximate tree height. This is based on equal legs of a 45, 45, 90 degrees triangle. My nephew uses that method when dropping trees for our home site. Jon.
   / Loblolly Champion Tree in TX #19
That’s ok for estimating, but the big tree registry will come and accurately measure to the nearest foot before naming a new champion. They will use one of the instruments that I suggested in my previous post. The same for diameter (circumference). It has to be measured at exactly 4.5’ (breast height) above the high point of the ground at the butt.
That is the method that I used. I'm probably within a few feet of being accurate. I wasn't able to figure out how to compensate for the slight uphill slope. Just guessing, I'm probably standing 4 to 6 feet higher then the base of the tree when I was 127 feet away from it. It's not much, so I don't think it should change my distance too much.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
Zero Turn Mower (A59231)
Zero Turn Mower...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
207283 (A52708)
207283 (A52708)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
