BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 3,458
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
I took a break from working on the Nova for a few days, had to help a friend with some computer problems, and had another friend that needed an extension for the ram on a hydraulic jack used on a homemade cherry picker. I gave him an unused air operated 8 ton tall jack that was one of a pair I had bought years ago to make aircraft jacks for my Debonair, but it was about six inches shorter than the old one, and wouldn't lift as high. I used a piece of 2" hot rolled bar stock and was able to turn it down, bore one end to fit over the jack's ram, and drilled a couple holes to secure each end.
This afternoon, I got the actuators installed in both doors of the Nova so I'll have remote/keyless locks in the doors, They were easy to install, screw the actuators to the mounting brackets, remove the latches from the doors, drill out a hole on the locking lever and install a retainer clip for the link from the actuator. Reinstalled the the door latches with the actuators and was done. Was a pretty easy job.
Still need to run the wires and install the ducts from the door to the body that they run through, but I need to mount the control unit first.
I'm also mulling over putting a connector in the wires so the door can be removed without cutting the wires. I have several types that will work, just need to decide which one to use.
I think I'll have a couple of friends come over and get the trunk lid mounted tomorrow, it's ready to go.
