What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ?
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I sold my ZD1211 great machine btw but lacked power on my steep hills.
I bought Two ZD1511-72 & absolutely love them but I need more power & an 84 inch single deck for my Hilly 18acre application.
My farm ground is too rough for FD models tiny deck wheels running on the ground.
i like the ExMark 96 & 144 inch cut but they are WAY Underpowered for my farm Hilly application AND rear discharge (n)
What IS replacing the discontinued ZD1511-72 ?? 🤷‍♂️
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #2
I don’t know, but if mowing 18 acres, I’d be looking at one of the finish mowers with multiple decks and a 100” cut or more.
If the ground is really rough, as in your case, you might be a candidate for a 50HP cut with a pull-type finish mower.
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #3
Yeah, 18AC and hills is out of the lawnmower range. And it looks like money is no object for you. I'd be moving to a tractor as Dude says. :cool:
I used a 6 7 & 9ft RFM behind a JD 4700 & 4720 Tractor for many years but the Zero is the way to go around chicken houses, barns, ditches etc.
I don’t have big open areas.
84-90 inch single deck is perfect
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #5
If a diesel powered zero-turn is under powered I agree with the advice of getting a 40-60 hp tractor with finish mower. Make sure its a cab if there are no obstructions.
Then combine that with a zero turn to get around the chicken houses.
I can't imagine how long it takes you to mow 18 acres with a zero turn. I spend about 3 hrs mowing 3-4 acres and my ground is somewhat rough.
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #6
Once you get into the multi deck zero turns, I *think* they are all rear discharge.
I know Case-IH/NH offered 40-50 HP tractors with 84” mid mount mowers that were side discrarge. They would be a really tough, rugged mower, larger cut, but slower than a ZT. Get one with a cab and it would make a great large acreage mowing machine. They may have stopped offering the 84” decks, but there’s some used ones out there.
I had planned on buying one for the cab, but I could own 3 used diesel zero turns for the same price.
The JD 4720 66hp tractor & 110” Befco 110 inch RFM was good but scalped places mowing at 4.5 inch height.
The ZD1511-72 isn’t saving me any time at all BUT it mows WAY SLICKER & I can trim WAY BETTER.
I’m mowing 8.5-9hrs to mow it all.
I normally mow 3-5hrs 2r3 times per week.
I loved rear discharge with tractor RFM but HATED the RD deck clumping with ZD1211-72RD (n)
It mowed just as slick as a SD but when grass got hi on me : it left windrows / clumps & I tried absolutely EVERYTHING from mulching blades, removing baffles & rubber flaps etc
It wasn’t too bad IF u mowed before grass got too hi
Cab tractors are too top heavy on my steep banks plus I can’t use them in my chicken houses lol
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #10
That's the reason I keep a ZTR. The Ford gets mowing duty for most everything else with a rotary and a flail. I'll be getting a ditch/bank mower shortly for some of my areas. I spent my allowance on chipper so I'm saving up for that. :D
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A50854)
2000 GMC C7500...
New Holland B95 Backhoe (A50490)
New Holland B95...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2011 TRAIL-EZE  TE80HT48 HYDRAULIC TRAIL (A50854)
2011 TRAIL-EZE...
