T7530 Brake leak issue.
   / T7530 Brake leak issue. #1
Bjørn
New Holland T7530 2007 model
I have a brake oil lekage on rear axle . It look like it leaks on one of the actoators sitting top of the axle. Is it posible to buy a rep set for these Actoators?
   / T7530 Brake leak issue. #2
Call the parts department, they sell parts at the parts department. If it's one of the mineral oil brake fluid, they leak. Best thing we did was buy anything but New Holland brake fluid. Works a lot better with non NH fluid.
   / T7530 Brake leak issue. #3
Beginning to wonder whats going on here;
Yes I have call the parts department but they dont have the rep kit for these only the actuator . The Actuator is realy expensive. A guy working at the Tractor work shop told me that I must only use mineral brake oil on this Tractor. If I not do that it will start leaking cause of damage seals….
   / T7530 Brake leak issue. #5
Yes but we bought some other mineral brake fluid that stayed way better.
Pallet of Fluorescent Traffic Cones (A55787)
Pallet of...
Dump bed (A51692)
Dump bed (A51692)
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A55788)
2013 Ford F-550...
11'x19' Single Steel Carport (A53316)
11'x19' Single...
