Mar 16, 2023 / Mahindra Range Shift #1 R Rojmo New member Joined Oct 7, 2020 Messages 2 Tractor Mahindra 3540 HST My Mahindra 3540 HST is stuck in midrange. The shift lever is turning where it goes into transmission but it won’t change to low or high range. Any help would be appreciated. Thanks Rojmo
Mar 18, 2023 / Mahindra Range Shift #2 3gunr Veteran Member Joined Apr 17, 2018 Messages 1,182 Location wentzville mo Tractor mahindra 2538 mahindra 2810 cub cadet 7260 massey 255 Set at idle RPM Center forward and reverse pedals Try raising front wheels with loader, Sometimes bumping F and r pedals helps
Mar 18, 2023 / Mahindra Range Shift #3 3gunr Veteran Member Joined Apr 17, 2018 Messages 1,182 Location wentzville mo Tractor mahindra 2538 mahindra 2810 cub cadet 7260 massey 255 Also make sure tractor is not in 4wheel drive that makes mine very hard to shift.
Mar 18, 2023 / Mahindra Range Shift Thread Starter #4 OP R Rojmo New member Joined Oct 7, 2020 Messages 2 Tractor Mahindra 3540 HST 3gunr said: Set at idle RPM Center forward and reverse pedals Try raising front wheels with loader, Sometimes bumping F and r pedals helps Click to expand... Thanks. I will give it a try.
Mar 19, 2023 / Mahindra Range Shift #5 oosik Epic Contributor Joined Aug 22, 2012 Messages 20,808 Location AMBER, WA Tractor 2009 Kubota M6040 SO...... how did it go, Rojmo???
