etpm
- Joined
- Jun 30, 2021
- Messages
- 2,408
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Hi All,
I'm still working on getting the power steering installed in my Yanmar YM2310. I finally have everything done the way I want it except for fittings and hose. I want to use re-usable fittings. And some of the fittings I want to use are only available for 2 wire hose. The power steering cylinder has 8 inches of travel and this means the two hoses attached to the cylinder must move too. The hoses will have 90 degree fittings to the cylinder. So as the cylinder moves the hoses will need to be able to curl and extend. The existing hoses on the tractor for the FEL are all 1 wire so I have an idea about how flexible it is. What I don't know is how much less flexible is the 2 wire hose. Oh, I should have said the hose is all 1/4" hose.
I would rather have the hoses come out of the steering cylinder vertically because it would put way less motion and strain on the hoses but at this time I just can't figure out a good way to route the hoses to achieve this. So, is there much difference in the flexibility of 2 wire 1/4" hose compared to 1 wire?
Thanks,
Eric
Thanks,
Eric
