Tools & equipment that are fantastic.
   / Tools & equipment that are fantastic. #381
CS top handle arborists saw. I did have to swap out the muffler and loose the cat converter. Runs fine and like I said before, the key to a good cutting saw (any make) is a properly sharpened and sharp chain. The new Stihl's are really choked up. You have to mod the mufflers right off and retune them plus their prices went through the roof. The old ones run good, I have one as well, it's 45 years old.
   / Tools & equipment that are fantastic. #382
My old cutting partner had an ancient Echo top-handle that was an excellent little saw. Lacked all modern safety (no chain brake, no vibe mounts), but it was as reliable as a brick wall. I went with the Husq.435T for my top handle, because it was the highest-HP top handle on the market at the time, and it's... okay. I don't like the flimsy chain brake (takes two hands to reset), probably should've gone with the 020T (now 201T) that all tree pros carry, you don't need a ton of HP in a top handle.
I'll admit I haven't owned any of the latest-gen Stihl's, but a buddy of mine was over with his new MS-661 Magnum two weeks ago, and it was a screamer. No complaints from him, on that one. He gets a new saw every year, rotating a few thru his stable at any time, as he's a pro cutter that uses them all day everyday.
I'm not sure that Stihl's pricing is any higher today than in the past, though. In fact, it might have come down over the years. when scaled against inflation. They've always been expensive, but it appears they still manage outsell all other brands.
Asking the few tree pros I've known over the years, most are between Husqvarna and Stihl, with the primary complaint against Husqvarna being fragility/repair frequency, and the primary complaint against Stihl being only price. When a broken saw causes lost work hours, I guess the price of the saw becomes less important than it's durability or reliability. Not as much an issue for those of us using them at home for processing firewood, etc., unless it translates to wasted precious mid-winter Saturday daylight hours.
   / Tools & equipment that are fantastic. #383
Think I said previously that I 'had' a Stihl top handle arborists saw that got run over by a bucket truck and broke the crankcase. I wasn't about to purchase another one for 700 bucks when I happened on the Echo for just over 300. It's a tree and limbing saw and not meant for heavy cutting or bucking downed wood and for that it's just fine. I deal with the local Stihl dealer and the prices of new ones (I peruse the prices all the time), knock my socks off. The Cs is also lighter than the Stihl at 7 pounds fueled and ready to go.
   / Tools & equipment that are fantastic. #384
I guess this is a piece of "equipment" lol I really like my Xmas present from 5 or so years ago so I now own 2 of these one for home one for cabin. A Roomba with clean base. Cleans corners well with rotating side brush, keeps dust under control. it does occasionally get stuck on something however I've mitigated that after getting familiar with it. My wife gets a little upset at me when I'm sitting on my ace watching TV and tell her I'm vacuuming lol. It should be noted I dislike most forms of newer technology and gadgets but really am pleased with this contraption.
   / Tools & equipment that are fantastic. #386
Posting on the tire fiasco thread caused me to think about the hydraulic puller I bought at HF a few years back. What a tool. Makes removing harmonic balancers a snap as well as brake discs and drums and pressed in axle shafts. Couple pumps on the handle and they either let loose or they break in two.
Beats screw type pullers hands down. Not cheap at HF though, I think I paid 100 bucks for mine but it's saved my bacon many times. They come in 10 ton and 15 ton pull ratings. I have the 15 and I've never found anything that it won't pull. Comes in a nice blow molded fitted case too. Jaws are reverseable and adjustable.
   / Tools & equipment that are fantastic. #387
Is that the porto power kit they offer?
   / Tools & equipment that are fantastic. #388
I've got an Echo that I've had for 20+ years and I just can't kill it. A little on the heavy side, but not bad. This has a 20" bar, so it's not a limbing saw. It's cut a LOT of wood in those years!
Anyone I know that has a Stihl seems to have a hard time starting it. Even if it's been sitting for months, the Echo starts right up 3rd or 4th pull every time.
   / Tools & equipment that are fantastic. #390
I bought the Echo arborist saw this weekend largely on the good recommendation from 5030. It has to be about 1/2 the weight of my 18" saws. After the first start of the day, seems to start very well. My Dad used to have a light weight McCullough chain saw in the 1970s that was a similar design. There's a sticker on the Echo that says "made in Japan."
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
1619 (A58375)
1619 (A58375)
HELI 25 STRAIGHT MAST FORKLIFT (A52709)
HELI 25 STRAIGHT...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2246 (A58376)
2246 (A58376)
