Battery replacement
/ Battery replacement #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I’ve got this pump mounted on my water trailer pulled by my tractor https://m.northerntool.com/shop/tools/product_200578549_200578549
I’ll need a new battery to power it since the one in the Kubota isn’t the marine type and so discharges quickly
Are all marine type batteries the same as far as how long between intervals of start up to recharge?
Would be nice to have a battery that would run this pump all day and I could charge in the evening but I’m gonna guess that’s asking too much from a battery
Any specific suggestions on a battery would be appreciated
Thanks
/ Battery replacement #2
Thanks
This runs at 12 V 17A according to the data sheet. Thats 204 Amp Hours per hour.
Four of these 250 AMP HOUR batteries using 80% DOD (Depth of Discharge) would run it for about 4 hours, One would last an hour.
/ Battery replacement #3
Your Kubota battery is probably like a truck battery. Designed to withstand a lot of vibration, and then, like a car battery, intended for short discharges (starting the vehicle) and quick recharges (soon after the engine starts). Many find the alternator on Kubota's to be anemic, which may explain why your pump causes the battery to go low.
What you want is a deep cycle battery, frequently referred to as a marine battery. Recommended discharge is 50%, and never to exceed 80%, so a bit different from Andy's recommendation. (google to duplicate my results).
Your best performance will come from 2-6 volt batteries, wired in series. You want lead acid (the kind with water). I recently purchased 4 Duracell at about $108 each. Checking * ratings, they were highly recommended, as compared to the brand most car repair places sell. If you decide to go with only one battery, made are 12V deep cycle batteries.
Before you buy your battery charger, check amp hours of the batteries - that will govern the amp output of the charger you need.
/ Battery replacement #4
Why not just extend power from tractor to water trailer if they are always used together..... Even tractor idling, alternator should be able to keep tractor battery charged and still provide power to pump...
Not sure why you think you need marine type..... If it were me I would go with a Odyssey AGM battery....
/ Battery replacement #5
I agree with the suggestion to run pump off tractor battery and if battery doesn't maintain full charge something is wrong with battery,alternator or pump.
Thanks for all the input, so it sounds safe to assume that there isn’t necessarily a deep cell battery that will last longer in terms of powering my pump than another.
I do not want my tractor idling all day…… day after day while running this pump
Looks like unless I want to get into stupid money buying multiple batteries and running them in series than I will still have to start my engine to get recharged more often than I’d care to
/ Battery replacement #7
The link for your pump at Northern failed but I doubt a 12 volt pump was intended for "all day,day after day" operation. Sounds like you need a gas engine powered pump. If it were me I'd buy a new roller pump and reduce rpms of a used lawn mower engine to power it but you can buy a complete set up for what it costs for batteries and replacing worn out 12 volt pumps.
/ Battery replacement #8
I would rig up an alternator off a small gas engine.
/ Battery replacement #9
For all day every day I agree with small gas engine pump.... Perobabl cost less on long run the 12 VDC pump plus all the batteries and charge and "stuff"....
I have older version of one below and is just sips fuel and supplies a great amount of water even at a idle....
/ Battery replacement #10
The link dosnt work for me. Also what are you pumping that this pump needs to be on for 24hrs?
I built a small solar water pump setup got my garden and it wasn't super expensive. I used a 12v programable timer to really help the system.
/ Battery replacement #11
/ Battery replacement #12
I think this is not correct.
If it draws 17 amps for one hour, that a 17 amp hour draw.
The watts it uses is 12V * 17A = 204 watts
If the "all day" the OP is asking for equates to say 10 hours, then a 200 amp hour battery would fill his needs.
He could pick up two, one is charging while one is running the pump. He could also cobble up a solar panel system to power the pump if his pumping is stationary.
/ Battery replacement #13
My neighbor to the south is a big cattle rancher. Same as my neighbor to the north. Anyhow - he has two cattle watering stations - way, way out in the pucker weeds. He has a solar setup to pull water out of shallow wells and provide for his cattle. He seems very pleased with this setup. He sets them up in the spring - brings them in in the fall.
/ Battery replacement #14
Well, a 17A new load is not trivial.
Not sure why the OP didn't start with powering the pump off the tractor. Or perhaps a pump driven by the PTO?
The common mistake being repeated here is in believing electrical power is sourced from the battery. The battery is nothing but a buffer of electrical power, storage primarily for starting the engine but once running the battery helps average the voltage available to electrical consumers such as the ignition, lights, fuel pump, radio.
An ammeter would be most desirable but likely one is not fitted and if you didn't know you needed one it is not something we should undertake here. A very low resistor is needed in the ground lead from the battery. And a very sensitive voltmeter across that resistor.
Lacking an ammeter, a volt meter can provide a secondary indication of what is happening. Under power the "battery" voltage should be between 13.8 and 14.9v. Add the water pump and see what happens. If it doesn't drop below 12.6 then you have no trouble, the alternator is good enough. Fully charged lead-acid battery under reasonable load will drop to 12.6v. Could let it go lower for short periods so long as the tractor is running to charge it.
As mentioned earlier your tractor is most likely fitted with an automotive battery. These are not designed for regular discharge below 50%. Don't even like 50%. They are designed for short bursts of high current to drive the starter motor.
Deep cycle lead acid batteries are designed for more frequent discharges below 50% but commodity box store batteries can't do much more than 100 cycles without showing significant degradation.
For serious regular power cycles lithium is the lowest cost per kWh over the life of the battery. But I'm guessing $500 to $1000 for your application. 200Ah is not enough for 204W for 8 hours.
If your alternator doesn't have sufficient power then the cheapest alternative would be to shop for alternator upgrades. Lots of good inexpensive high power automotive alternators exist but I have no idea what mechanically fits your tractor. Electrically it is simple as a nail, modern excited field alternators have an voltage regulator. Basically hook up battery and ground and away you go. There is no concern about the alternator being oversized because the mechanical power drawn from the engine via belt is proportional to the amount of electrical power asked of the alternator.
/ Battery replacement #15
The link is useless. No pumps, no data - nothing. Sound like nyone did something similar to my neighbor.
/ Battery replacement #16
We have a tank with a pto pump. It works every time we turn the pto on. A small pto pump will be easier to deal with than a 12v pump. On side by sides and 4 wheelers we use 12v pumps.
I was using a 44 cubic yard dump trailer cleaning up after a hurricane in south Florida. I ended up with a generator on the truck bed running a battery charger to operate the dump. Since nothing was open because of the storm, I had to do that for a couple days. Finally bought some welding lead. Ran welding lead from truck batteries to trailer batteries and no problem at all after that. I bought a disconnect and put it near the trailer connection so I could leave the trailer on homestead AFB. FEMA had a camp there, but I didn't stay there overnight. Most times I left the whole rig there. But sometimes I couldn't get a ride, so had to un hook trailer to go in for the evening.
/ Battery replacement #17
Grumpycat I agree with much of your post but. . .
The amp draw for a 204 watt pump =~17amps. 17amps * 8 hours = 136AH
/ Battery replacement #18
IMHO you should get the battery with the highest amp
rating that will fit! When its below ZERO you will have
plenty of amps to start you vehicle
willy
/ Battery replacement #19
Thanks
One of these would pump water all day/every day, as long as there's gasoline in the tank!
Not a bad price starting at $230
1 in. 79cc Gasoline Engine Clear Water Pump - 35 GPM
2 in. 212cc Gasoline Engine Semi-Trash Water Pump - 158 GPM
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
John Deere Zero Turn Lawnmower (A65579)
John Deere Zero...
Round Bale Livestock Feeder (A66408)
Round Bale...
Stout Buckets 66-9 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets 66-9...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
Landhonor 65' Retractable Air Hose Reel (A66408)
Landhonor 65'...
