How to evaluate a used tiller
/ How to evaluate a used tiller #1
Big Hammer
So I found the tiller that I wanted to purchase, but there’s no tractor onsite to test it out. Is there anything that I should look for visually? I’m nervous because I don’t know the seller, and they are a couple of hours away. Thanks for anything you can suggest
/ How to evaluate a used tiller #2
Check the oil in the gear box. Have them pick it up with a loader or something similar, spin the pto, make sure it feels tight. Look at the blades, that will tell you how many hours it's run. Take the cover off the chain or gear drive , see how it looks. They aren't really a technical machine.
/ How to evaluate a used tiller #3
If you can roll it back so the tines are not touching the ground...you should be able to turn it with the slip clutch...
Thanks guys. Here’s a pic. Seller says it’s only got about 20 hours on it. But I believe it’s a discontinued model from the manufacturer.
/ How to evaluate a used tiller #5
Kuhn is a reportable brand. They even make implements for JD repainted green... Look at the tines to see if the seller is being straight up or not. Worn tines equal lots of hours.
/ How to evaluate a used tiller #6
Like others said Kuhn is a great brand. If the tines are good I'd buy it
Andy
/ How to evaluate a used tiller #7
Andy
As others have said Kuhn is a know, reputable brand. Check gearbox oil for the amount and color (water contamination) and tines - although they can easily be replaced. If worn doesn't always mean lots of hours, could have been used in dry hard soil; my experience. But the picture looks like it's a good machine to bet on.
/ How to evaluate a used tiller #8
Check the 2 tines on each side that are closest to the depth skid shoes. If the ends of those 2 tines come to a point, it has a lot of acres on it.
Check the slop in the chain by holding the pto still with one hand and rock the tines forward and backward. If the tines move 4 inches or more, the drive chain needs tightened or replaced. If you feel or hear something in the gear box while doing that, it's not a good thing.
That's about it, other than cosmetics.
/ How to evaluate a used tiller #10
Just by looking at it you can tell it doesn't have a lot of hours, and it wasn't abused, the paint is barely flaked off on the flap, all the warnings are still there even the reflector on the left is there... most tiller only operate a few hours a year so its pretty hard to go wrong... nice find ... it be worth changing the oil in the gear box and remember to grease the CV's joint every time you uses it.
/ How to evaluate a used tiller #11
I've had the same one for about 20 years that I bought used. It was lightly used on sandy soil.
Gets maybe 5 hours a year with me.
They do a great job with few problems.
Grease the U joints and the grease zerk on the side, check the oil in the gear box. You know, the regular maintenance stuff.
Most of my tines are still good but two need replacement after hitting rocks.
Happy tilling.
/ How to evaluate a used tiller #12
50+ year old Howard rotovator. All original. Used yearly till a few years ago. Curved tines making virtually self cleaning.
Had a friend complain about new TSC tiller performance. Those blocky straight tines are like a hay baler over vegetation. Tillage not nearly as fine and smooth.
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
2015 Bobcat E42 (A64126)
2015 Bobcat E42...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
4004SFL (A59228)
4004SFL (A59228)
1994 New Holland 580 Square Baler (A63688)
1994 New Holland...
KMC 12 Row Rip Strip Till (A64126)
KMC 12 Row Rip...
