John Deere 4200 three point lifts too high
   / John Deere 4200 three point lifts too high #1
Cadjockey
John Deere 4200
Looking for some help. My three point lifts too high and slows motor down when it gets to the top, seems to creep down too. I tried the adjustment rod with no change what so ever, What could be wrong?
TIA
Dan
   / John Deere 4200 three point lifts too high #2
A component called the rockshaft can be adjusted to prevent over travel. Some tractors even have a stop on the control itself you can set to limit how far up and down it goes. As far as the drifting down that is probably a leaky seal within the three point lift itself.
I tried the adjustment rod with no luck at all.
   / John Deere 4200 three point lifts too high #4
may be a bad seal or O ring in that feedback value assembly?
I just read about some friction disks on the linkage shaft? Anything think true to that?
   / John Deere 4200 three point lifts too high #6
I believe what you are referring to are possibly friction plates to provide resistance to the position control lever to prevent the lever from moving on it's own due vibration and what have you. This would very likely not have anything to do with your problem. Others here have mentioned a couple of areas worth checking into: Seal in feedback assembly and/or seal on 3pt hitch piston.
I hope this helps.
Mini Plate (A57149)
Mini Plate (A57149)
40 (A52708)
40 (A52708)
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2025 Hillcrest 14716SDH T/A Dump Trailer (A56858)
2025 Hillcrest...
2322 (A58376)
2322 (A58376)
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
