MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,126
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Hahahahaha!thank you everyone, esp moss rd for your detailed explanations and links to mole info...
I am pretty sure i have grubs, but I also have a lot of earthworms too.
The biggest challenge I have is I am not at the ranch for more than 24-36 hrs at a time. I know setting traps and managing them is timing consuming and a requirement. So, getting the upper hand on a consistent trapping regiment will be difficult.
As far as NC declaring moles a protected animal, I would have to change that law...
Has anymore every used the nomol mole traps? Here's a video on them:
thanks aga1 in for everyone's help and experience !!!
"Our experience is that the average yard contains 1 to 3 moles. We've had as much as 7."
Hahahahaah!
The first year I started trapping in August and got 29.
The second year, I started at first sign in the spring and stopped counting at 50.
Did the same thing for 5-6 more years, always stopping at 50.
Some days I'd get 3-4 in one day.
"Moles are solitary"
I've pulled 2 out of one hole within an hour of each other.
I realize I had an extreme experience, but I still have to laugh.
As for those traps, they may work well. However, they look pretty weak, as you can set them with your hand. The reason I went to Victor Out O Sight is that it seems to be the one that kills the fastest, rarely misses, and you can tell of it's tripped without having to dig it up. The guy in the video said he checks them every 3 days, so who knows how long it takes to kill the animal?
I tried the spike traps, they'd trigger, but when I pulled them out, there was no mole, just a dirt cavity under the trap. So I'm thinking the mole probably got stuck, then dug its way out, and crawled off to die. I don't like that idea.
I also tried the Nash Choker Loop traps. While they had a catch ratio similar to the Out O Sight, they rarely killed the mole. They just held it there with the mole flailing around for hours and hours. In fact, on several occasions, I came to find the trap gone! I'd search the yard and find the mole had pulled it out of the ground and dragged it across the yard. That's unacceptable to me. Then I'd have to dispatch the mole by hand. I'd put it's head on a brick and whack it in the head very, very hard with a metal trowel to end it's suffering.
The Out O Sight rarely missed. Twice out of the 300+, I had 2 where it pinched the mole by the loose skin and just held it there. Never found any others alive in that style trap. Always dead.
But as I mentioned, there's reports that it is no longer as strong as it used to be and consumers are not happy. They are reporting that it's no longer strong enough to cut through soil, and doesn't kill the animal quickly.
The step-on scissors type trap might still be strong enough. I only used those a few times because my father in-law bought them for himself. He had a lot of trouble setting them across the tunnels, but I managed to make them work OK. And, with those, you can see if it's been triggered or not.
The ones in the video you linked to require you to pull the sod back to check them.
Depending on price, though, they look effective. You'd have to try them out. And you need 2, one facing in each direction.
