Dipstick came out today
/ Dipstick came out today #1
Bloodyrun
Member
Kioti dk40se
my engine oil dipstick got yanked out brush hogging today, didn't notice till putting tractor away, was spurting oil out of the stick hole was running it for 2 hours, how much came out,??? Iam going to change the oil just in case
/ Dipstick came out today #2
I don't think anyone will know the answer as to how much oil came out. Best thing to do, is to find the dipstick, put it in the engine again and check the oil.
/ Dipstick came out today #3
Hahaha, by your title, I thought maybe this was a political post.
I am typically extra cautious, so I would probably do a complete oil change in case debris got in. Better safe than sorry.
/ Dipstick came out today #4
Totally agree on your oil change idea. Better safe than sorry.
/ Dipstick came out today #5
Why are we changing the oil. Find or buy the dipstick and check it then. Isn't that the point of a dipstick, to know how much oil is in the engine? It is not like you are going to run it until one has been installed anyways. After you have a dipstick and checked oil, add oil if low. It as simple as that.
/ Dipstick came out today #6
2.25 qts. just kidding.
I'm not sure I would change the oil unless it was close to the recommended oil change interval.
Buy another dipstick, check level, and add oil as needed.
/ Dipstick came out today #7
Spurting oil out of the dipstick tube sounds more like a blowby issue (rings or breather) to me. Where is the engine dipstick located that it could be yanked by brush? Is the turbo overpressuring? Fuel pump seals? What does the oil look, smell, and feel like? Is there fuel in the crankcase? Any oil analysis for comps?
I'd check to make sure the mechanicals are ok before just assuming it was a pulled dipstick ... unless you know the dipstick was pulled by something/someone, in which case you should be able to find it pretty easy as you'll know where you ran over the bushes, or where you checked the oil last.
/ Dipstick came out today #8
Depending upon the dipstick location , height, angle, straight, curved, etc. the crankshaft could easily sling oil out the dipstick tube.
/ Dipstick came out today #9
We can't do that because it makes too much sense. We are not living in the age of doing things that make sense anymore. Those days are long gone.
/ Dipstick came out today #10
Shouldn't talk like that about son-in-law...
/ Dipstick came out today #11
Seems there have been a few other cases of missing dipsticks reported here lately but they were supposedly blown out by crankcase pressure and I’m not sure what brands of tractors they were.
/ Dipstick came out today #13
Yes crankcase pressure is what I'd look into. I have cleared jungle many times. Never lost a dip stick.
People are making this way to complicated, the dipstick was always kinda loose AND I was in heavy brush hence it was just pulled out and gone, I have a new one and oil change is due so I'll change oil awhile, thanks all appreciate it 😀
update , got new factory dipstick and nice tight fit 👌
