Tree worth much?
/ Tree worth much? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We have a handful of these large, I presume Oak, trees. I'm first wondering is this a "Pin Oak"? (picture of leaf which was under said tree) If so that means it's a red pin oak?
You can see the right side of the fork....has snapped off at the top. I'm debating on cutting this 'branch' off....but now what? sell log outright? Have cut into an oak beam? Cut into dimensional lumber for future use? It's large on its own, fairly straight however, I have no idea if there is rot working its way in.
All these trees seem to be dropping tips of branches that appear to have died. Maybe it's just what the tree does, maybe it's in the latter stages of its life. They will be massive projects to remove (I like to get the root ball out) and I have NO plans as I'm currently sitting here to take them down, unless there is more value to take them down today rather than wait 4-5 years for them to die and then they're worthless from internal rot or something.
In the end, I'm wondering just what do I have here?
These are large trees, I have four of them within a Joe Montana heil Mary pass distance of each other.
/ Tree worth much? #2
The only thing they would be good for is firewood. For anything like a sawlog they would have to be straight and relatively knot free. Mills generally don't like houselot trees anyways, as they often contain nails, wire, dog chains, and who knows what other foreign objects.
/ Tree worth much?
I probably have 8-10 foot lengths that are straight (if not maybe leaning) with very few if any branches/knots. One of the trees probably hits near 20 feet (as estimated from the ground) with one/two branches but those could be cut points making it two 10 footers verses a 20.
Is it the type that makes you think they're firewood or moreso that they're off private property. (I totally get they won't want to ruin a saw with an errant nail or dozen)
I can vouch for only the last 50 years while (my wife's) family has owned the farm.... prior to that, no idea what might have been done but, given their location, they do NOT make good fence lines.
I DO like nice fires too!!
/ Tree worth much? #4
There is an oak wilt that is killing oaks in my area, I’ve lost a few. Red oaks are more likely to die from it. Sorry I can’t help you on any value.
/ Tree worth much? #7
We get a bunch of oaks that I have to drop every year due to the tops starting to die and drop branches. 99% of the time the tree is bad in the middle somewhere. We often find, what looks like, big slugs in the tree when we are cutting them up. They are mostly pretty decent for firewood but most pretty poor for saw laws. We can get some 8-10 sections out of some but not close to what you would normally want out of a tree.
/ Tree worth much? #8
A logger generally wants to cut enough trees to justify bringing the equipment necessary to cut, remove and haul the logs to the sawmill.
If you personally have access to the machinery, trailer and truck needed to haul the logs to the sawmill, then they could have some value at the sawmill if you can haul them yourself.
Another option is to look for someone with a portable sawmill who could cut them into dimension lumber. A friend cut up one spruce tree for me some years ago. We both came away with a lot of very useable lumber from one tree after a day of sawing.
/ Tree worth much? #9
I have a gigantic oak tree on the front corner of my yard I thought about cutting it down because it is a very messy tree with branches every spring.
Then I watched an episode of growing a Greener world where they talk about how much habitat a tree that size supports between insects and animals.
I'm not a tree hugger by any stretch but I do like providing habitat for critters, so I'm leaving it.
Curious as to why you want to cut those all down?
/ Tree worth much? #10
I'm with you, I cut a lot of firewood but mostly blow down. I have bunch of standing dead that are home to bats, squirrels, woodpeckers, raccoons,etc. Unless they threaten something I leave them until they tip over.
/ Tree worth much? #11
I took down a tree at my FIL's place after he passed. It had a pair of pliers in it that the saw found.
I've checked with both big & small sawyers and none of them will touch a residential tree. Firewood seems to be the most likely outcome for your trees.
/ Tree worth much? #12
I don't know what limits insurance companies put on loggers who harvest trees in the forest, but i suspect they won't insure them against dropping a tree on someone's house unless they pay the price for that kind of specific coverage. Tree service companies probably pay some stiff liability insurance premiums.
/ Tree worth much? #13
Here is the video. Just start watching from 8 minutes in until 24 minutes in.
It's very interesting something that you don't think about.
/ Tree worth much? #14
Just plant replacement trees. We have a pine plantation, such as it is. Rather than clear cut, as is typical, we will select cut and replace every tree .
My plan is to get a small sawmill to process some myself. Wife is not 100% onboard yet.
/ Tree worth much? #15
This is certainly better than nothing depending on the type of tree you plant. But it's pretty tough to replace a 100 plus year old oak tree for habitat
/ Tree worth much? #16
Oak wilt has spread from western Wi to Se Wi here in the last 6 yrs. One or two oaks dead has become 5 to 10 a year. Looks like it's moving into your area by Knoxville. You may get many more dying in the next few years.
Sawmills generally want 40acres here, not 4 trees, no yard trees or dead and decayed ones.
Firewood is usually only worth the labor put into it. If you like doing it, and have a need, great. But a little may become a lot, and trying to make money on it could become a fools errand.
Habitat - depends if a large number of dead trees are tolerable either from an asthetic view point, or because leaving them is wasting good wood. Otherwise, hollow logs are premium habitat for wildlife.
At the rate the disease moves, you may have 4 more dead next year, then 10 more the next. The disease can kill very slowly at first - trees that die tend to have stunted growth rings for the last decade, branch tips that cease to grow or die back, then "it's dead", when the reality was that it was sick for a long time. Look over the others to see what the situation is.
Oak wilt
2009 Dodge Charger Sedan (A64194)
2009 Dodge Charger...
2025 Wolverine PT-16-02C Class 2 Three Point Hitch Skid Steer Attachment (A64553)
2025 Wolverine...
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
New/Unused Electric Winch (A65583)
New/Unused...
Front Tank Bracket (A64126)
Front Tank Bracket...
