M9540 with M35 loader, hose information
/ M9540 with M35 loader, hose information #1
fordstick
Caledon, Ontario, Canada
Kubota TG1860 / Kubota M9540 / DB Case 2290 / Ford 8N
My M35 loader rubbed a hole in the hose on the upper right hydraulic cylinder for the bucket curl. Can’t get a custom hose made because one end of the hose is proprietary (uses a red plastic circlip to hold the connector! Anyone have a part number for this hose?
Wow, the M35 in your manual looks very different from mine. I don't have any steel lines on my M35 at all. Anyway, on further inspection, the so called non-standard connector had a number stamped on it: 9031142. Google has it as a New Holland 9032604 (which supersedes 9031142). The picture of the New Holland part matches the hose too.
/ M9540 with M35 loader, hose information #5
Wow, the M35 in your manual looks very different from mine. I don't have any steel lines on my M35 at all. Anyway, on further inspection, the so called non-standard connector had a number stamped on it: 9031142. Google has it as a New Holland 9032604 (which supersedes 9031142). The picture of the New Holland part matches the hose too.View attachment 785649View attachment 785650View attachment 785651
Ok, disregard the manual I posted. I Googled M35 loader and the only one that came up with that name was the M35 loader made by Miller Loaders. Definitely not the same loader as yours.
That's indeed a special fitting. Looks like a swivel joint that allows the hose to swivel easily under pressure. A really bad choice as far as serviceability goes, in my opinion.
Hopefully you can find a replacement for it.
2019 PETERBILT PB520 GARBAGE/SANITATION TRUCK (A59823)
2019 PETERBILT...
12' CONTAINER (A52706)
2005 John Deere 7320 (A60462)
2005 John Deere...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
Towable Light Tower (A60352)
Towable Light...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
