Gov't mandates gas can flame arrestors.
/ Gov't mandates gas can flame arrestors. #342
Those were FUN!!!! Government definitely went a bit too far when those went the way of the DoDo bird.
Little kid died when the weighted dart that was meant to be thrown up in the air came down and pierced her skull.
We had fun with them too. My friend stuck one into his parents's house roof. And I think I recall someone getting one in their foot.
They were taken away by his parents and we never saw them again.
/ Gov't mandates gas can flame arrestors. #343
Mine was a tongue in cheek comment. I only played them a few times.
/ Gov't mandates gas can flame arrestors. #345
I bought a new 5 gallon can a few years ago and along with the poorly designed, poorly functioning ventless spout, it had a flame arrester in the can. It was just a fine mesh plastic screen inside the opening of the can. When I tried to fill the can at the pump it kept blowing gasoline back out of the can and shutting the nozzle off. I got angry (POed) and shoved the nozzle into the can hard enough to push the flame arrester into the can. I fished it out later after the can was empty. I bought an EZ Pour spout and vent and the can works perfectly. Just like the old ones.
/ Gov't mandates gas can flame arrestors. #346
Why does it seem like these 'safety features' are always so poorly designed and impractical to deal? That they either cause people to eliminate them or they actually create more problems than they fix? I'm pretty sure the fuel spilled by folks filling due to the damn screen in the can causes far more release of fumes to the environment than the 'ventless spout' fixes. But I guess as long as someone feels like they did something and can check off an accomplishment the actual results don't matter.
Same goes for the energy efficiency and 'environmentally friendly materials' for modern refrigerators... I'm going out on a limb and saying that there is more waste and environmental harm from modern fridges that only last 5-7 years and have to be disposed of than the old school ones that lasted 30 years. Factor in the cost to manufacture, materials used and disposal and the 'environmental improvements' are a step backwards. But it sounded good, right?
/ Gov't mandates gas can flame arrestors. #347
Most of those screens I have seen are removable for filling. At least the cans I have do. Not an issue.
/ Gov't mandates gas can flame arrestors. #349
Kind of defeats the debris catchment doesn't it?
The filter effect only works one direction. If you keep the debris screen in for filling and for pouring you defeat the purpose of the filter so you need to remove it for one or the other
/ Gov't mandates gas can flame arrestors. #350
I self mandated to remove it entirely since I don't like the splash back while filling and don't pour gas on burn piles, wood stoves or hot engines.
New/Unused Quick Attach Auger with Three Bits (A61166)
New/Unused Quick...
1987 GMC WHITE ROLL OFF (INOPERABLE) (A60736)
1987 GMC WHITE...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
Vertical Steel Well Tank (A61570)
Vertical Steel...
