K5lwq
Elite Member
- Joined
- Aug 6, 2017
- Messages
- 4,919
- Location
- Mineola, TX
- Tractor
- Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
In this case the oil was too cold to prime up. The OP has fixed the issue. But welcome everyone to TBN.
Agreed and who would want to keep a fluid like this in their tractor ?In this case the oil was too cold to prime up. The OP has fixed the issue. But welcome everyone to TBN.
I know you said you used all Kioti filters, however, I had this happen to me once before on a Cub Cadet I was working on. It will be a slight nuisance, but drain fluid and put old filter on and try it. If it works, you just might have gotten a bad filter. Better than chasing your tail "looking" for solutions. Good luck.I've done a fair number of fluid changes and this is the first time I've encountered this. Loader jerks a few inches and that's it. PTO spins, but it doesn't seem very vigorous. Steering isn't happening (no power).
I'd over-filled a bit so I removed fluid to just under full.
Haven't run for more than a couple of minutes (total) for fear of damaging something. All Kioti filters. No issues changing anything. I am using semi-synthetic fluid, spec'd better than Kioti.
How best to work through this?
Like oil conversations, filling filters prior to install is highly contentious. I have alway filled my filters prior to install. For one installed horizontally, stand upright, fill till full, let sit for a minute or so allowing the filter media to absorb fluid. Once absorbed, you can cleanly install horizontally without fluid loss. Wet media vs dry is always better and pushes any air out.I don't know about your tractor but some of the older tractors and equipment I've worked on over the years with horizontal filters dad a plug in the top of the filter housing, to fill the filters after installing
Try filling it is sucking maybe cause it needs filled to work my kubota was filled all the way up when I changed it.What about filling the hydraulic fluid from 1/2 on the stick to right to the full mark?
When you put the old filter back on did you confirm that there was not a doubled up gasket left on the case?
You mention a different fluid... What fluid are you using specifically?
Most tractors will have the hydraulic filter at the suction side of the pump. Some choose to still run a screen, others don't.A couple of things not mentioned so far is the fact that the majority of hydraulic filters on a hydraulic system, filter on the return as the filters cannot handle full system pressure.
Transmission filters are different as you are not talking about 2000 lbs of pressure.
Most systems will have a screen on the intake to the pump to prevent large pieces from the sump getting to the pump.
Get a schematic of your system so you know what is involved/included within the system, get to know your system, always check the simplest thing first, always, no exceptions.
if you fail anything in your system you will probably contaminate the entire system, this means you disassemble every hose, cylinder, valve in your system, if you do not, you will recontaminate the entire system and have ongoing problems until you clean the entire system.
The reason manufactures install filters upside down is so you can not prefill, does that tell you something, just because oil is new does not mean it’s clean, do not prefill oil or fuel filters as this is bypassing the filter, just like putting dirty oil or fuel in your engine or transmission. Price out an injector for your engine, want to change them because you pre-filled the filter?
I would be fearful of blowing a seal somewhere doing thatWonder if you could use a compressor to put some pressure on the tank to force some fluid to the pump?
Jeeze what a saga! I've a Kubota and the filters and hydraulic fluid in the shed - over a year now - waiting to change it out.. One guy told me about the ShopVac 'trick' but, never watching it done up close or even knowing which filters which and getting really stung on a fuel pump R&R (>$700.00) I've really been avoiding the fluid change.OK, and the winner is... JimR! Fluid was just too darn cold. I pulled out a propane heater (that I've never used) and blasted the filter and underside. Started up and zero complaints from the pump. Ran for a bit and shut it down and installed the new filter (no fluid added). Fired up and all was still good. Took a few laps around my driveway, hooked my forks back up and put it away. I have to say that this fluid, now that the pump can actually fetch it(!), feels VERY nice- everything feels so much smoother and quicker. I will see how things are when I go to use it (minimal use this time of the year- mostly relegated to moving around crates of firewood).
For what it's worth, this fluid is supposed to last a lot longer (won't be doing a fluid change for a while- likely send in a sample at 400 hrs; filter changes per schedule, of course).
Again, I cannot state how appreciative I am of everyone here. There are not a lot of forums with a LOT of great and knowledgeable folks.
Pretty sure you would not blow a seal doing that. The case is vented and many use that technique to get fluid flowing. But anything is possible I guess.I would be fearful of blowing a seal somewhere doing that
quick reply here. Did you happen to dial back the hyraulics knob under the seat?I've done a fair number of fluid changes and this is the first time I've encountered this. Loader jerks a few inches and that's it. PTO spins, but it doesn't seem very vigorous. Steering isn't happening (no power).
