New Kubota ZT Smoking on Start-Up.
   / New Kubota ZT Smoking on Start-Up. #21
I have had multiple Kaws and in multiple mowers. For the most part none of them smoked until the one we have now. 31 HP Kaw. Commercial Bushhog HDZ 4 and it requires a lot of choke to start and it does smoke for a bit. I don't really think anything about it. I look at how the engine performs once warm. The thing is a BEAST and won't bog even in high grass.
Kawasaki are very loud engines but they do a great job. Wear hearing Protection. I don't always but I have to say that in case the safety police are listening : )
I really will not buy a mower with any other engine.
   / New Kubota ZT Smoking on Start-Up. #22
Awesome! ! ! That's good to hear.
When it happened, I searched the forums for some reassurance, and there was little. I did notice that it smoked more if the engine was run for short periods, and shut down without letting it idle for a minute or two.
However, like I said, almost 5 years removed, it’s a champ and never smokes. You’ll be alright.
   / New Kubota ZT Smoking on Start-Up. #23
I have a 35 HP Kawasaki in one of my zero turns and a 37 HP Briggs Vanguard EFI in the other.
I'm still not sure which engine I like better, both run/perform well.
   / New Kubota ZT Smoking on Start-Up. #24
At least Kawasaki isn't too cheap to not use valve cover gaskets. Briggs is... They use blue glue instead, just like Kohler does.
   / New Kubota ZT Smoking on Start-Up. #25
My Deere X540 occasionally smokes when starting and has done this since the day I brought it home. Sometimes just a little other times fogs the shed. Right at 500 hrs on it now and have never had to add oil between changes.
   / New Kubota ZT Smoking on Start-Up. #26
If you say so.
Yet the Vangaurd parts manual shows parts # 809732 for OEM replacement valve cover gasket
   / New Kubota ZT Smoking on Start-Up. #27
replacement yes, OEM no. But then I adjust my valves yearly. 12 bucks for a sheet of gasket paper is highway robbery. I make my own.
   / New Kubota ZT Smoking on Start-Up. #28
Wrong again
I just went down and looked, and YES there is a valve cover gasket from the factory. (I bought this machine new in 2020.)
Repete, it did come with a valve cover gasket.
The Vanguard series is their commercial grade engine that they use on commercial grade zero turn mowers
My Vanguard engine came with the oil guard system (dry sump engine with a separate oil tank) holds 6 quarts of engine oil. My Kawasaki 1000v engine holds 2 quarts of oil.
2000 Cummins DGDB 100kW Standby Diesel Generator (A56857)
2000 Cummins DGDB...
Hustler super Z zero turn (A56859)
Hustler super Z...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
207278 (A52708)
207278 (A52708)
Pickup Instructions (A55272)
Pickup...
