Grease Couplers for FEL
/ Grease Couplers for FEL #11
You'll never find the correct zerks at TSC.... they are BSPT (British standard pipe thread). I t was real easy for my dealer to mail me a couple of each size used on the LS.
I have broken many a zerk over the years..... until I got these extras from the dealer.... haven't broken one yet on the tractor, going on 4 years now.
I don't know if they enlarged the holes on my loader (LL3300), but the 'long' locknlube fits easily on my loader......
/ Grease Couplers for FEL #12
I use a Lock-n-Lube grease gun, but recently got their accessory kit for some of the hard-to-reach fittings on my FEL and BH.
Yes. There is one that has a screwing lock mechanism that I use to get to the burried zerks on my machine. There is also a needle type fitting for extreme situations that can work with zerks. All of the items in the kit have fittings that attach to the standard lock n lube fitting, so you don't need to modify your gun.
/ Grease Couplers for FEL #13
I have the long reach lock-n-lube on my grease gun. It works well enough, better than the end that came with it. However, like the OP stated, the fit into the recessed pins can be very tight. Fortunatly, only the 4 pins on the very end of my loader were tight. I could barely squeak the lock-n-lube in there. I decided to hone out that recessed part. I though about pulling the pins, taking them up to my neighbors machine shop, and boring them out on the lathe. Just a few thousandths would be all. But that seemed like overkill.
Instead of removing the pins and using a lathe, I simply removed the zerks, cleaned the recessed portion really well, and used my Dremel tool with grinder drum to remove a bit of material. It took me a bit of doing, but now the lock-n-lube fits like the rest of pins, snug but easy enough to get in and out.
/ Grease Couplers for FEL #14
Maybe okay, assuming they're always slathered in grease, but are you concerned about having removed all the plating which protects the pin from the elements? Around here, tractors rust indoors, due to our high-humidity spring days when everything in a shed or barn is dripping with water.
/ Grease Couplers for FEL #15
Nope! I am not concerned about removing plating from the inside radius of the recessed pin do to corrosion. It would take a LOT of corrosion to make the pin head unusable. And if you're really worried about it, paint it.
With our seasons, we have rust too. I'm not near the coast, so I don't have to worry about salt in the air, but even if I did, this would still be a non-issue for me. Those recesses are slathered in grease, but that is no excuse or protectant against corrosion. I never did paint mine, nor do I intend to. I just simply do not care enough about a bit of surface rust in the recessed area.
/ Grease Couplers for FEL #16
I got a Lock-N-Lube to go on my DeWalt battery powered grease gun. THEN I found that the L-N-L would not fit ANY of the recessed zerks on the FEL, grapple, tractor or rear blade. I said to hell with it and went back to the standard fitting that came with the DeWalt.
/ Grease Couplers for FEL #17
I switched to that exact coupler and it malfunctioned and the result was a broken coupler and and broken off nipple on my zerk.
Good news was that Macnaught sent me out a replacement free of charge and free shipping.
Bad news is having a huge issue finding the right size zerk to replace the old on. After several trips to tractor supply in town no love. I ordered several in the size I thought was correct with no love. Finally I think I got the right size 10mm not sure of the thread size yet but with the tight recess how do I install the new zerk?
Thinking I gotta get a thin walled 10mm socket that is deep and then figure out a way to get it going into the hole. Maybe there's a spacer I can add to the socket to keep it out far enough to grab the threads. Whata pita. Bad enough getting the correct size zerk then not being able to install it.
I get the reason for resessing the zerks - working in brush etc its very handy as long and nothing goes wrong.
I also tried many couplers and the one I found the easiest to work with was the Macnaught but it malfunctioned. Can win for loosing.
Anyone have a handy tip for installing zerks in recessed fittings??
I used a deep socket with a spacer inside that kept the fitting straight to start the threads. I think I used a plastic pen cap that I cut to size with a razor blade knife. I suppose a bit of rubber vacuum hose might work as well
/ Grease Couplers for FEL #18
Use a regular grease gun tip, just don't wrench it tight onto the gun hose. That way you can loosen the tip and release the pressure to remove from fitting. Since putting this trick into play, makes greasing equipment much easier and haven't broken a fitting! Or just replace zero with the ball type fitting and use a rubber tip to insert grease. Just remember to wipe all the crud out first.
/ Grease Couplers for FEL #19
Replace recessed grease zerks. Thin wall - deep socket. I cram paper towel into the socket to bring the zerk up to the face of the socket.
/ Grease Couplers for FEL #20
I thought everyone did this? It's the only way I've ever used them.
Therein lies the problem. I spend 4x more time wiping the stupid crud out of the recessed zerk counterbore, than actually greasing anything.
iDrive TDS-2010H...
2022 John Deere 1025R (A53317)
2022 John Deere...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
1982 LOADSTAR LS25LB 96"X30' DOVETAIL TRAILER (A59823)
1982 LOADSTAR...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
2019 F150 (A61306)
2019 F150 (A61306)
