Crank no start
   / Crank no start
If it were me I'd pull out 1 relay at a time and clean the sockets with contact cleaner . And reseat ur relays to start. lots of dirt there that can give you a bad connection.
I actually just did that, I am searching for the bleeder screen for fuel now , all the videos I'm seeing are different than mine
   / Crank no start #12
This might be a referance for the relay locations as well:
  • Relay locations.pdf
   / Crank no start
That looks like what I have. Thanks, I will try and replace the relay tomorrow.
   / Crank no start #14
If you have 12 volt source and a volt/ohm meter you can test the relays, see attached.
  • Relay Testing.pdf
   / Crank no start
I have replaced all the relays and still no start
   / Crank no start #16
On the number 6 relay in the picture (Fuel shutoff) while turning the key to the on position see if the relay clicks by putting your finger on it. If it doesn't I would make sure all fuses are good and if they are it could be a defective ignition switch.
   / Crank no start #17
Do you have voltage at the fuel shut off solenoid now that you replaced the relays? If you do and the solenoid isn't opening the fuel valve, you have a bad solenoid. There are normally 2 solenoids; an opening solenoid and a holding solenoid and both must be working.
If you don't have voltage at the solenoid then the problem could be a broken wire, bad connection etc since you replaced the relays.
   / Crank no start
I was told I could run a hot wire to the solenoid or just pull the solenoid to start. Is this correct?
   / Crank no start
I will check that when I get home. Thanks
   / Crank no start #20
How many wires on your solenoid. Usually there are two so you will have to run two wires. Don't anything about your specific solenoid but give it a try. It can't hurt anything.
HAMM HD+9I VO DOUBLE DRUM ROLLER (A51242)
HAMM HD+9I VO...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
Kohler Generator (A50322)
Kohler Generator...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
