The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #31
I understand mowing the fields with the weeds, but in the first set of pictures you posted, it looked like you where mowing a nice hay field. Is that correct? Is there a reason for mowing a hay field now that improves the hay?
Its because they only wanted 1 hay mowing that year. We took hay in July and then did a final mowing to return some organic matter back to the soil.
Some guys will cut hay for years and never put anything back, which just results in diminished tonnage.
Gotta put something back.
Thanks. I'm trying to learn about hay, and improving pastures for cattle. It's kind of overwhelming.
Once you get that backhoe up to your brothers land and clean it all up, you’ll be well on your way.
I will help you however I can. I bet TxJim will be able to give you some great advice since you are in similar climates.
   / The Life of a Custom Mowing contractor #35
looks like some heavy duty elec corridor lines traversing your place. bucolic property you have
I believe those are the Peach Bottom nuclear power plant or power lines from the Coniwingo Dam hydro electric power plant.
   / The Life of a Custom Mowing contractor #37
   / The Life of a Custom Mowing contractor #38
How long to complete that job? 72” mower?
It took me 12 hours, it had been logged 3 years ago so I was able to pretty much turn most of the debris into smaller chips , but it was rough due to the stumps.
Getting ready for next big cut…..
2018 TowMaster T-12D T/A Flatbed Trailer (A55852)
2018 TowMaster...
2018 Deere 323E (A53317)
2018 Deere 323E...
Kubota L4701 (A53317)
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
1998 TRAILMOBILE DRYVAN (A55745)
1998 TRAILMOBILE...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
