check
Elite Member
- Joined
- Sep 26, 2008
- Messages
- 4,011
- Tractor
- 2009 Kubota BX25
I was told something similar when my furnace started making a strange buzzing vibrating noise. The service people said I had to replace the fan motor. It was under warranty otherwise it would’ve been well over $1000, but even after the warranty deduction they still wanted $500. I went here on tractor by net for advice, and even posted a video with the buzzing noise, and somebody came up with the idea that it was simply some loose metal furnace tape. Lol. In fact, it was the A coil vibrating against the Plenum. I whacked it a couple times, and haven’t heard that sound ever since.I used to think Jenn air and Maytag were excellent products. Then several years ago, they bought out by Magic Chef and built in the same factory. They don't seem as good anymore. Not sure Jen Air is still made.
Back then, you could buy a $400 appliance and get a part for it for $20.
Seems today, you can buy the same appliance for $1100 and a simple switch will cost$300.
I put in a new HVAC system last year. The furnace has a variable speed motor. The furnace cost $1200. I was told the cost of the motor if I needed to replace it was $900.
They also replaced the little drain pump and reservoir that drains the condensate. It pumps the condensate up to the exit of the drain which is above the floor level of the furnace. I was suspicious, so I tried out the old one, and it worked just fine. I sent a video of the old one still working to this repair service, which was supposed to be a popular, reputable dealer, and they said “OK never mind you don’t have to pay for the new one”. LOL again. I don’t trust any of these guys anymore.
