Best tiller for CK2610
/ Best tiller for CK2610 #1
Michael Johnson
Kioti CK2610
I'm looking to buy a rototiller for my CK2610 but haven't been able to find good info on what would work well. I don't want to buy something that my tractor will struggle to pull. If you can help with weight, width, and overall performance I would be grateful.
/ Best tiller for CK2610 #2
A 5' tiller would be a good size for that tractor. I wouldn't go larger than that. You want the tiller to at least cover the width of your tractor so you're not compressing your previous row. Weight won't be an issue if you stick to that size. Your soil will determine your speed and number of passes.
/ Best tiller for CK2610 #3
I run a 5 footer behind a 28 hp tractor with ease, Really depends on soil conditions. A little moisture helps alot.
/ Best tiller for CK2610 #4
I have the 5' Tarter built one from TSC on my Mahindra 1626. It's been great. I like that it has 6 tines instead of 4 and it's reversible.
I've tilled sever acres with it.
Thank you for the replies. My tractor width on rear tires is also 63". I have a HST also and I was mainly concerned with the performance of a larger tiller. It sounds like a 60" tiller would be fine if I go slowly. Are there any tillers I should stay away from?
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
John Deere 5100E (A64911)
John Deere 5100E...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
