Better parking brake warning needed.
/ Better parking brake warning needed. #21
Good posts! I'm ordering the motorcycle brake light switch from Amazon $6 and change. I'll make an extension like Smokey did. I remember seeing that inspiration before. It's hard to press down and touch your toes Kubota :LOL:
Got mine from Digikey. I suppose any petal switch will work however.
I suppose it will - This is one mod Kubota should adapt. It's too easy to drive off with their weak-ash brake on.
/ Better parking brake warning needed. #23
With the new ones, I wonder if adding it will impact the ECM. They seem to be touchy. you could add one of those idiot alarms instead. Do any tractors today have a warning?
/ Better parking brake warning needed. #25
The the parking brake on my L2501 is this small lever that has to be pushed forward to engage. When pushed forward, the little red knob on it is completely blocked from my view. So I keep forgetting it is on. But I have just ordered the switch linked by ruffdog and a warning light to install.
Would like to see the bottom part of the lever Smokeydog made for his B26. I'd rather have a more accessible brake lever than the one that came from the factory.
/ Better parking brake warning needed. #26
The one on my Branson is the hand lever type located down at the floorboard. I despise those the locking foot brake pedal is so much easier.
Both of the tractors I've had used locking foot brakes for parking. The one on my old JD750 worked pretty good, but my Kioti wasn't real well thought out. There's a rod with a handle on it you need to pull up before you press the pedal. Trouble is, most times I need to set it my foot's already on the brake and that doesn't work so well. The handle on the rod tends to come off...I've got it JB welded on, hopefully that keeps it that way. I also had to rig up a return spring on the latch mechanism because sometimes it doesn't release.
On a similar note I've got to come with a reverse indicator light for mine...I'm always forgetting which I'm in when doing loader work. The fwd/reverse lever has a lot of slop in it so I don't think a plunger switch would work...maybe a magnetic one?
/ Better parking brake warning needed. #27
I need to come up with a 4 wheel drive indicator. I sometimes forget to disconnect the front axle.
Mike
/ Better parking brake warning needed. #28
The parking brake linkage on the B26 is different from your photo. I simply had to add a piece of flatbar at right angle to the OEM short handle. Not having to bend over to engage while pressing the brake so much easier. Can feel the notches of the ratchet paw easier and set the brake firmer. Better of two modification. Both improve multiple user operation.
There might be a way to bring your lever up and function better.
Lowering the FEL, 3pt, turning wheels and setting parking brake all important on our hillside farm.
/ Better parking brake warning needed. #29
I've always believed that if you are going to set the parking brake, do it so that whatever you are using won't move until you release it. It sounds like that isn't possible on at least some of the tractors mentioned above.
I might also be the only person left in the world who uses the parking brake on my pickup. I only do so on hills.
With a cable E brake I'm against setting the brake when it is not needed. (on the flats) Somebody scolded me for doing that - they said it's an emergency brake not a parking brake. What are you going to do if if it's all stretched out when you really need it? :oops:
So I stopped setting on the flats.
/ Better parking brake warning needed. #31
I always lower implements before getting off the tractor. I only need to set the parking brake when there's a tendency to roll. This particular parking brake doesn't seem to set as hard as the brakes on my other tractors. It's been bugging me since day one so this thread was timely in inspiring me to add a brake light indicator.
/ Better parking brake warning needed. #33
At this point, it's just one more modification among others I've already made.
One among many :rolleyes: ;)
/ Better parking brake warning needed. #35
There are two Kubota tractors at a farm I attend regularly. An M 8200 special utility and a M 105 S 4x4. Little parking brake lock under the dash. If I have to use it, I keep a 4' long 2x4 with me to bang it off. Their parking brake system is pretty sorry.
/ Better parking brake warning needed. #36
LOL I think I am used to too old of tractor............ Set the uphill brake hard, if I forget to take it off, the tractor drives in a circle until I remember..........
Best,
ed
/ Better parking brake warning needed. #37
If the freaking E brake worked like it should we wouldn't need a better indicator because there would be no driving off with it on, right? :rolleyes:
If I add an idiot light to my tractor, does that make me an ________?
/ Better parking brake warning needed. #38
Following! I do this more often than I would like to admit. Interested to see all of the possible solutions.
Right, problem with the 50+ hp HST is it will walk away with the rear implement engaged and the brake on like no problem and the warning light is an anemic dash icon that doesn't really show once you get a good layer of dust/dirt on it aka open station tractor.
Got my footswitch from amazon yesterday...
/ Better parking brake warning needed. #40
My friend hacked the B26 ecm with a parking brake switch to kill the engine if HST pedal moved much like the operator present seat switch. Said his wife wouldn’t pay attention to a warning light. Maybe a better use of the seat switch? Some people need a different 2x4 to get their attention.
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2010 Scag STT52V-27CH 52in Zero Turn Mower (A61572)
2010 Scag...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
