rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,931
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
The most important feature (other than the gauge wheels) is the width. I recommend an 8' rake because when it's set to 45 degrees, it covers your rear wheels. Don't use a top link, use a chain so that the teeth stay at a set position while the tractor roller coasters up and down. You can still raise it up for transport. My ARPS rake used teeth commonly found at many sources. You will probably bend 1 or more and it takes some heat to return them to correct position. Otherwise will need to be replaced.
I found on my Woods rake that I was better off replacing teeth than heating & re-bending them. That was back when I was still trying to get it to de-rock an acre. No go....
I'll accept some bend as you can see in those old photos of our Woods in earlier posts.
Hey! All all rake teeth the same or interchangeable? The teeth on the Woods rake have about half their width flat and parallel top and bottom, are fairly thick metal, but the sides are oval rather than flat..... does any of that matter?
Maybe EA could tell us about rake teeth and more info on why they think theirs is better Facts mean a lot here on TBN, where we are hands on kind of people. Just saying one brand is better than another is something we see all too often & tend to dismiss.
I will say that the EA model with adjustable offset as well as adjustable angle sure catches my eye. I wish that the Woods rake had that feature. It would be very handy. All of our back blades have offset, but not our rake. The Woods does have a flip down blade...but no offset.
I'll give that chain idea a try. Thanks for the idea In the past we use a standard top link along with a couple of bags of sand for weight - but even with the wheels the rake still bounces too much.
rScotty
