Need help with a Belarus 250as
/ Need help with a Belarus 250as #1
BspCraft
Belarus 250as
Hello, I have a Belarus 250as tractor. The hydraulics stopped working a few days ago and I went on a witch hunt. Found the issue that the hydraulic drive gear box is shot and so is the drive gear in the clutch housing. My question is do I have to split the tractor to get the drive gear out of the clutch housing.
Picture below.
I have a video on my phone that I can upload to YouTube and link if needs be.
Went ahead and linked Incase it helps.
Sorry for mistake, here is 250as breakdown of clutch housing. Looks like I needs to be split.
/ Need help with a Belarus 250as #4
I hope someone can help you out, but Belarus is pretty obscure these days.
/ Need help with a Belarus 250as #6
Belarus is known for premature clutch failures. since it involves the same procedure, scour utube for your tractor clutch replacement vid, or just google. may as well replace clutch assembly as well once split. hope the job goes smooth, welcome to the forum. if the drive train is still good, prob worth repairing if you do your own work regards
/ Need help with a Belarus 250as #7
I thought he was seeking counseling because he had a Belarus.
/ Need help with a Belarus 250as #9
I've wanted a Belarus since I was a kid; as a toy, of course, I don't want to rely on it.
Oh, they're ok machines. My neighbor still has one. It's a pretty big one. The support system for them was bad at its best. One day he was driving it down the road, front end just snapped in two. It was a pain to get that home. Solid round axle broke.
/ Need help with a Belarus 250as #10
I realized long ago that before I buy I Belarus I ought to buy a welder.
Thank you for the help
Lol 😂
/ Need help with a Belarus 250as #14
sorry i really couldn't help, i couldn't find utube split vid of your model tractor. so are both hyd drive gears available before you start work? & are you set up to split a tractor (i never did)? safety 1st, you know that, helper would be handy, still think would be worthwhile if straightforward repair... regards
Yeah I've found the parts and I have some 1/4 in t-steel to make a splitting stand. Cause it's like $1500+ for a splitting stand and at minimum $600+ for the parts. It still drives fine and everything, just no hydraulic power.
Thanks for looking for vids by the way 😊
Thank you everyone for your help. Me and my Dad have decided to turn it to a pulling tractor. Since the tractor isn't worth putting this much money into it. We have another tractor here to use.
Sincerely Bsp
/ Need help with a Belarus 250as #17
Sincerely Bsp
always pays to do the homework & posting here. good decision making process rather than regret after the fact :)
& you can always "upgrade" the iron horse at any time. continue to post progress & status of the tractor. cheers
Thank you 👍
2007 Mazda 3 Hatchback (A61574)
2007 Mazda 3...
2007 Genie AWP-30S 30ft Manlift (A61572)
2007 Genie AWP-30S...
2004 CATERPILLAR 242 SKID STEER (A64279)
2004 CATERPILLAR...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2025 Dingo Ditch Bucket Skid Steer Attachment (A61572)
2025 Dingo Ditch...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
