looking for rare metric bolts
/ looking for rare metric bolts #1
Jrasband
Southwest VA
Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
Need m14 x 1.25 structural bolts. I need 8 at 50 mm and 8 @ 75 mm, does anyone know where I can find them? Search engine is not turning up much except euro wheel lug bolts. This is to replace the bolts that mount the front frame and loader to the engine block on my LS XG3032
/ looking for rare metric bolts #2
Did you try an LS dealer. I needed a bolt for my JD, larger metric than the hardware store had. The JD had it, of course it cost 4 times what it should have.
I plated the original frame due to it cracking almost in half and putting a small crack in the block. Seemed to be underbuilt
/ looking for rare metric bolts #6
MSC industrial. they have a online store.
/ looking for rare metric bolts #7
what grade are you looking for? 8.8 10.9 ? 12.9 ?
/ looking for rare metric bolts #12
ok no luck on mac or McMaster Carr.
/ looking for rare metric bolts #14
Are you sure it's 1.25 pitch? Most metric fine thread in that diameter is 1.50.
I will double check that they are in fact 1.25 pitch, thanks.
/ looking for rare metric bolts #17
Eurolink is the premier US distributor of metric fasteners and specializes in complimenting and extending your basic fastener lines with hard-to-find metric fasteners manufactured to both DIN and ISO standards. As the nation’s leading source for hard-to-find metric fasteners, Eurolink offers access to more than 100,000 quality C-class parts from countries such as Germany, Italy, Switzerland, Poland, Spain, France, and Great Britain. Regardless of your required size, material, or finish, Eurolink has the European resources to meet your demands.
I haven't used this company.
Yeah seriously, at 16 that would be insanely expensive!
/ looking for rare metric bolts #20
Yup but you wanted the impossible... seems like there is next to nothing in extra fine threads in M14.
2008 HINO 26FT NON CDL BOX TRUCK (A59905)
2008 HINO 26FT NON...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61306)
2022 Greenworks...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
Informational Lot - Financing (A61307)
Informational Lot...
2012 Ford E-250 Cargo Van (A59230)
2012 Ford E-250...
(2) 3"X24" HYD CYLINDERS (A60430)
(2) 3"X24" HYD...
