Best Attachment for Parking Lot Leveling
   / Best Attachment for Parking Lot Leveling #21
Send some pictures of you working with your new implement and let us know how you like it.
   / Best Attachment for Parking Lot Leveling #22
Leveling and smoothing an area with different size aggregate can be very annoying. Things are going great then big chunks buried at different times and depths start getting pulled up and everything goes to crap.
   / Best Attachment for Parking Lot Leveling #23
Pics or it didn't happen. :)
   / Best Attachment for Parking Lot Leveling #24
If you're talking to me I've pulled up cinder block chunks, old bricks, big chunks of broken up concrete even old tires.
   / Best Attachment for Parking Lot Leveling #25
Talking to the OP.
   / Best Attachment for Parking Lot Leveling #26
Buried rock is Mother Natures way of telling who's boss. Some of our rocks are just not exposed yet. This exposed stuff is out back...and buried under the dirt in front yard.
   / Best Attachment for Parking Lot Leveling #27
I have a lawn maintenance account that has about an acre of land that tractor trailers use. Part is a long path and the rest is the loading dock area. It was probably started as crusher run many years ago but now it's a little bit of everything. It's extremely hard packed and develops pot holes terribly. They have asked me to help maintain it. I would drag and level it out monthly just to keep things a little easier and smoother for the trucks driving through.
Although money is always an object, it's not my number one priority. I want to get the option that makes the job easier for me. In other words, I don't mind spending extra if it gets me home earlier.
I can get a 6' landscape rake for a little over $600. I can get a 6' box blade for about $1600. I can also get a 6'-7' land grader for a little over $2000. I tried using my 6' scrape blade the other day and it struggled to break through the hard pack. I'm sure that will improve as I maintain this area but I think I need something to really break through that top shell of the ground.
Tractor is a DK5310SE Kioti so it should handle these fine. But I'm not 100% sure how I'd like to proceed. Any opinions? In all honesty, I think the landscape rake would do great used on a monthly basis but I admit, I've never used a land grader. I'm just not 100% sure that's the right thing for this job though.
An acre isn't all that much. 43560 sq feet. Just over 200 X 200.
I've got about 700 feet of driveway I maintain. Every year. More than once a year. Water finds a depression, freezes, makes a pothole, grass likes to grow everywhere except where I plant it, always got that hump in the middle, drainage needs tended tp once in a while.
I bought a 5 foot Box Blade for my little Kioti CX. The reason is -- I didn't know what to get so I looked on line and watched professionals who did driveways for a living. To a man they used Box Blades.
So that's what I got. It works. What it doesn't do is more my fault than the fault of the BB. Plus, there's so many other things you can do with a BB. The more versatile a piece of equipment, the better I like it. I can't afford to go out and by a piece for every single task.
My buddy was having trouble tilling up his garden last spring. He didn't have a PTO tiller. All he had was a little Kohler 1 cylinder tiller and no way that would bust through the sod. No way. The garden was also filled with corn stalks from the previous year, dead tomato plants, vines, weeds, etc. Heavy overgrowth.
I took my BB, lowered the scarifiers as far as I could and took everything up. Tore it up good with several passes. Then I took my EA Wicked 55, lowered the jaw and ran along with the lower jaw digging in and picking up everything with the lid at the end of a run. Then I took it and dumped it in the burn pile.
My buddy was amazed. And he was a professional Farmer at one time. Unfortunately, one that lost everything. Anybody that lives in the Country knows those guys and it's seldom they're fault. It's usually the fault of bad luck and/or bad weather.
Long story but the moral is, BB's are versatile. I don't know about Land Planes.
   / Best Attachment for Parking Lot Leveling #28
A valuable addition to a BB is a hydraulic top link and side link. Then the BB gets real close to the perfect tool
   / Best Attachment for Parking Lot Leveling #29
for my money a land plane and a pile of fill at the site, use the fel to distribuite fill to the right areas and the landplane to level it out. I do not like to disturb packed fill but YMMV.
   / Best Attachment for Parking Lot Leveling #30
Man you sound so much like me with the grass:) I think I have more money invested in the yard than the house.
Box blades are handy, I like the powered ones (harley) but they are real money and more maintenance than anything else I own.
I have 2700 feet of driveway and the harley is great, but, I think a guy could manage with a good box blade. The most important things I have found, keep the road above grade, and have as much material to work with as you can afford.
Best,
ed
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2014 Mobility Ventures MV-1 Van (A56858)
2014 Mobility...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
ATTENTION PLEASE READ (A57149)
ATTENTION PLEASE...
Giyi Excavator Pallet Forks (A57149)
Giyi Excavator...
2011 GMC Sierra 1500 4x4 Ext. Cab Pickup Truck (A56858)
2011 GMC Sierra...
