Cooking Mice
/ Cooking Mice #1
Tpondel
Gold Member
NW OHio
Deere 3033r
Seems nearly every time I start the Deere 3033R I get grass, fur, lots of smoke and a burnt mouse smell coming from the exhaust stack.
The lid has a grate on it but there is definitely room in-between the actual pipe and the lid for vermin to climb down.
Does a mouse in the exhaust create potential engine issues? is there some sort of high temp grate that I can attach on the pipe itself to keep them out.
Thanks for your ideas and comments.
/ Cooking Mice #2
start it more often, kill 2 birds with one stone. the mice are not the problem it is what they bring in to make a nest (in the exhaust under the hood is a different story) that is the issue.
/ Cooking Mice #6
I leave the hood open on my vehicles - tractor, pickup, riding mower. Mice seem to not like the open area. Keeps them out of the engine compartment, passenger compartment and exhaust.
/ Cooking Mice #7
Might want to check engine area for mouse may have nest.
/ Cooking Mice
I check it often and so far no issue.
seems they like to come up the tires. Put the big sticky pads down today at each wheel and hopefully that helps.
/ Cooking Mice #11
I've heard they taste like chicken...🤔
:ROFLMAO:
/ Cooking Mice #14
Little buggers once packed my exhaust with pin oak acorns a few years ago. About the size of a marble. Upon startup they shot out like a blunder bust, ricocheting and bouncing about inside the metal equipment building. Quite lively entertainment for a moment figuring out what was going on. Fortunately no damage and a one time event so far. All evidence of the acorn massacre gone the next day.
/ Cooking Mice #15
For all the bucket and flapper guys, the exhaust on the OP's tractor is a very short open pipe that terminates under the hood. There is a small gap between the pipe and a "floor drain grate" that is fastened into a hole in the hood.
/ Cooking Mice #16
steel wool wrapped around the end of the exhaust so that the wool forms a seal against the bottom of the grate. Mice cannot deal with coarse steel wool.
/ Cooking Mice
You guys got me thinking. How about stainless bird spikes? The kind you use in a barn. If flexible, wrap near the top of the pipe and secure with clamps.
even stuff some of that steel wool in between the spikes.
/ Cooking Mice #18
Hardware cloth, bend over end of exhaust pipe, secure with SS hose clamp. Same thing I do on vehicles to keep them out of the intake.
/ Cooking Mice #19
Mouse piss and exhaust valves protecting shiny cast iron cylinder walls and piston rings.
What could go wrong? 😂
/ Cooking Mice #20
I had a similar experience with mice and the side-exit exhaust of my old JD 110 lawn mower. It had been in a shed at my parents' house for many years before I got it. They had put mouse poison in the shed, and at some point the mice collected the poison and rolled it into balls about the size of grapes and hid them in the 110's muffler unbeknownst to everybody. I wanted to see if the old 110 would run, so I put some fresh gas in it and jumped it. When it eventually started, it made a huge cloud of the stinkiest smoke I've ever smelled and blew half-burned long-dead mice and poison balls everywhere. It then ran like a champ.
I also shot a big old mouse nest out of the unload auger on a combine once too. That was a bit of a mess since those mice were still alive before the auger was engaged.
