Mf65 multi power oil
/ Mf65 multi power oil #1
markw1969
mulino, or
John Deere 3032E
Need help on mf65 trans oil. I have a 1962 mf65 with multi power transmission. I see the manual calls for 80-90 wt mineral oil. Is the miles gear oil ok or is it not gl1? If that’s even important. The local MF dealer wants $110 for 2.5 gallons vs granger at a bit more than half price. If I’m on the wrong track please pount me to the right one at a decent cost???
/ Mf65 multi power oil #2
Stick with the mineral oil ! I'm not sure what the part no. is but I use NAPA brand on my 1959 M-F 50 ! I'll get back with You later on a part no. there 2 different weights that NAPA sells one is 80w90 & the other one is straight 90w I use the 90w in my 1959 M-F 50 which takes 8 gallons , & comes in 5 gallon containers ! I'll have to check my receipt from last year , But I'm sure the price has gone up since then , I'm sure it's not as expensive at what your looking at :unsure: ! & welcome to TBN .
/ Mf65 multi power oil #3
I just did a on line price check for the NAPA mineral oil GL1 90W , & the current price for a 5 gallon container is $139.99 sticker shock! so it has gone up quite a bit! & was showing out of stock .
/ Mf65 multi power oil #4
It's been debated a lot. Most of the people I've talked to run Permatran instead of GL-1.
Personally I run Mystik JT-5 because I run that in everything. Specs said it would meet Permatran specs. Haven't used my tractor hard yet but so far, it hasn't had any issues with JT-5. Permatran was
I think from what I've read, the non multipower MFs have to run GL-1. The Multipowers should run the more modern hydro fluid.
Mystik was 99.99 for (1) 5 gallon bucket. I bought two since it needs 8 gallons. Permatran at the dealer was $121. So Mystik was a little cheaper.
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
New 2025 NextGen 7x20 Equipment Trailer (A61166)
New 2025 NextGen...
2006 TerraGator 8104 (A63118)
2006 TerraGator...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 JEEP GRAND CHEROKEE (A62130)
2014 JEEP GRAND...
