Kioti lk2554
/ Kioti lk2554 #21
Ok I unfortunately do not have the drive gear I had to use it on my new engine when I replaced it. But this is where I think your problem is. You will have to remove the hydraulic pump again to confirm.
The drive gear is a reduction type gear box mounted to the back of the injector pump. You need to remove the hydraulic pump then remove the gear box and inspect the splines and gears. I will post a picture of what the back of the injector pump looks like and the part I am taking about circled in red.
If I had not used it I was going to offer it to you for free.
/ Kioti lk2554
Ok that upgrade pump is now 1400.
How do o text the gear. Visual
/ Kioti lk2554 #23
If you can find a way to turn the shaft while it is on the tractor that would tell but I do not think that will be easy. If you could turn the shaft then it is bad. No way should you be able to turn it with it attached to the tractor.
/ Kioti lk2554
Ok what time will you be here. You don’t know how much I appreciate this.
/ Kioti lk2554 #25
Lol you are not that far away if you are in Little Rock so that is not out of the question. Lol
/ Kioti lk2554
All right then back to the barn. So what do you know about John deer bulldozers. I can’t believe they put a damn computer on it. My brother put a new injector pump on it and I think he got it out of time. It will run for 5 seconds and **** down. Every time I see Electronics I wanna choke an engineer
/ Kioti lk2554 #27
Not much but if the pump was out of time I doubt it would start at all. That sounds like a fuel shut off solenoid problem. Something is telling it to shut down or power to it only when starting.
/ Kioti lk2554 #28
Here is a screenshot from the parts diagram. This is the parts I circled that I believe the problem is.
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
