buckeyefarmer
Epic Contributor
Jeez... you guys are old.
"I remember when we stored data on a Victrola!"
I counted bits with an abacus.
Abacus! We used our fingers, and sometime toes.I counted bits with an abacus.![]()
I knew some blond guy that couldn't count to 21 unless he was naked...!Abacus! We used our fingers, and sometime toes.
"I’m wondering if it’s worth going to a 4K pc and projector for large room presentations. Mostly PowerPoint and some video. We currently project with a standard projector to a 12 ft wide screen. Any experience?" NO it isn't worth it. And there is no reason to. Your projector doesn't do 4K anyway. So.....
I would think it would make a huge difference.
The higher the resolution, the higher the pixel count.
People who have 4K TVs talk about how much sharper the pictures are.
As you spread the picture out on a 12 ft screen, I have to think you get a much better picture.
I don’t have a 4K to know, so hope someone that has a 4K projector can chime in. The projectors sure cost more.
Whoa... back up! Correct data, but wrong conclusion, because those receptors are coupled to some mighty good zoom lenses. One is not simply absorbing the entire screen worth of data into their eyes like a scannner, but rather we focus on where the motion or subject detail is on the screen. So, while projecting at 12' width at 16:9, your eyes may be zoomed and focused on a 6" square where the hockey puck is in play. Now rather than 4k lines, you're observing only observing 355 lines, which is quite detectable as different from 1080 (which would be only 86 lines).The answer is No. The human eye can not distinguish anything past 1080. We can't tell a difference on a higher resolution. We don't even have that many receptors in our eyes.
What sorts of things do you intend to project onto a 12' screen? Text, charts, spreadsheets, pictures, video??? How many people are viewing and how far away are they from the projection screen?I would think it would make a huge difference. The higher the resolution, the higher the pixel count. People who have 4K TVs talk about how much sharper the pictures are.
As you spread the picture out on a 12 ft screen, I have to think you get a much better picture. I don’t have a 4K to know, so hope someone that has a 4K projector can chime in. The projectors sure cost more.
Same here. I had a Commodore 64 using, i think it was called EazyWrite or something like that, took 20 minutes to load it and the printer couldn't do the part of the letter below the baseline. My prof was dubious about accepting it, but i finally talked him into it.I was the first person in my college to hand in a paper printed at home on a computer.
those printers were awful slow and ripping the perfs off made a mess.
For projections-they have short throw projectors so you can put them right up against the wall on the floor. Or do you want ceiling mount?
Looking at a high cost vs. low cost projector seems to make more of a difference in picture quality.
Lots of image processing to make the image clear and to offset any skew. Also quicker pixel updates so less artifacts.
Source material resolution is also key in getting better output as noted above.
