Thermostart problems. ARRGH!
/ Thermostart problems. ARRGH! #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
My Yanmar YM2310 thermostart failed. I bought a replacement. It only worked a couple times. With the air intake removed from the intake manifold it is easy to see the thermostart getting red hot and then see the fuel catch fire.
So, after the first one failed I got a new one from a different vendor. It gets red hot but no fuel flows. Another one showed up in the mail and it doesn't work either. Three different thermostarts. And they all look slightly different.
I am using Tygon fuel hose so it is easy to see the fuel in the hose. I have the hose disconnected from the reservoir and sticking up into the air. The fuel hose is full. I kept the thermostart red hot for a full minute on each one. No fuel flow. The fuel hose is not clogged.
Any ideas anyone?
Thanks,
Eric
UPDATE
I thought maybe blowing into the fuel hose might help. So I stuck a long hose onto the shorter one, turned the key, and blew into the hose. Fuel flowed for a couple seconds and there was a little flame and some smoke. Then the fuel stopped flowing. I let everything cool down and tried blowing into the hose again. So, started blowing, turned the key, watched the thermostart turn red hot, and kept blowing. For a full minute. Nothing. No fuel flow. Am I just getting Chinese crap 3 times in a row?
Eric
/ Thermostart problems. ARRGH! #3
UPDATE
Eric
Here's the real thing. (The box, not the used one on top). Thermostart is a Perkins patent.
dscn5123thermostart-perkinsbox-jpg.68476
/ Thermostart problems. ARRGH! #4
Buy one from Ford, or new Holland. Tell them 89 model 5610 series 11 (two). I know them machines have them. And they are the fuel type.
I looked for and was unable to find an original Perkins part. Do you know of a source?
Thanks,
Eric
I tried to get a USA made one from a Ford tractor dealer and they told me the ones they had were Chinese made. Darn it.
Thanks,
Eric
I really appreciate the advice from Roustabout and California. It's just too bad I can't find an original Perkins or a USA made Ford part. I am also looking for an original Yanmar thermostart but I'm no holding by breath. A NOS part would be great but any that are left are probably gathering dust in Japan or Viet Nam or some other Asian country. My original thermostart had burned out heating coils. It was a two wire unit and I assume one wire was either for ground or for energizing a solenoid type coil that would open a valve that let the fuel flow. In any case neither wire had continuity to ground or to each other. The original unit looked nothing like the replacement ones. It had a long case with a wire coming out of the end and another wire in the same location as the newer replacement ones. I think inside that long case is a solenoid operated valve.
Thanks All,
Eric
/ Thermostart problems. ARRGH! #9
Thanks,
Eric
I got that one pictured, from the local ThermoKing dealer. (The refrigeration unit mounted high on the front of a semitrailer).
Off-topic - One of the ThermoKing models from back in the day (70's) used the same basic Yanmar Diesel engine as my YM240. Obviously with some different features. The same basic engine was also in small commercial offshore fishing vessels. Those applications speak well for long term reliability and durability. I doubt the ThermoKing units are looked at between scheduled maintenance intervals.
Replica thermostarts are cheap on Ebay. Cheapest one I bought long ago had a return address from a London delicatession. About $16 total. I think that one is still in use on a YM186D that I sold. I wouldn't be afraid to buy from Ebay.
/ Thermostart problems. ARRGH! #10
Thanks All,
Eric
No the fuel valve is operated by heat from the internal heating element.
/ Thermostart problems. ARRGH! #11
Ground is made through the threads, same as a spark plug. Never seen a 2 wire version before. The heating of the coil should be what opens the check ball.
Just a thought, and I never heard of it needing adjustment, but maybe?
/ Thermostart problems. ARRGH! #12
/ Thermostart problems. ARRGH! #13
...looking for an original Yanmar thermostart but I'm no holding by breath. A NOS part would be great but any that are left are probably gathering dust in Japan or ...
The used one in my photo is OEM Yanmar. The trademark stamped on it (top side in the photo) seems to be Hitachi.
Nippon Denso and Hitachi are both suppliers of OEM starters, alternators, ignition parts for many Japanese auto manufacturers.
The ones for sale now use heat from a small element to open the valve. The original Yanmar one doesn't look like ones everybody uses now. The original has a steel case that extends about 1.75 inches from the hex. Something is inside that case. I don't know how the original ones work but they don't have two coils that get hot at the business end like they all do now. The original, like I said earlier, has 2 wires coming out, not one. The original is built differently.
Eric
/ Thermostart problems. ARRGH! #15
Are you sure what you have there isn't aftermarket? I thought the Perkins-patent one has been standard, widely used, since at least the Perkins 3-cylinder diesel in the MF-135. (1970, + - ).
I think it is stock. It was painted with the same Grey paint as the engine and the two wires connected to it both come out of the original wiring loom. And the loom looks all original.
Eric
/ Thermostart problems. ARRGH! #19
/ Thermostart problems. ARRGH! #20
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN# 7FWBE1622T1037829 (A61166)
2026 Steel Pines...
2017 Ford Escape 4WD SUV (A61569)
2017 Ford Escape...
New/Unused 2 Post Car Lift (A61165)
New/Unused 2 Post...
case 370 glass door never installed (A61307)
case 370 glass...
Kioti DK4510 (A62177)
2025 LandHonor HPF-11-3000G 48in Hydraulic Adjustable Forks and Frame Skid Steer Attachment (A60352)
2025 LandHonor...
